swapping a gas for diesel engine, massey 65
   / swapping a gas for diesel engine, massey 65 #1
peabody
My buddy , has a 1958 massey ferguson 65, with a gasoline engine.
He's wanting to put in a perkins diesel.
Anyone done this ?
Hope i posted this question in the right forum.
   / swapping a gas for diesel engine, massey 65 #2
I'd be willing to be he'd be a lot of time and money ahead by just selling it and buying another with a diesel engine. The engine alone is probably going to cost $2K.
I think your right.. but it was his grandfather s tractor.... he knows where there's a running perkins.. for 1500.oo $
I'm just trying to help him out.
He's a young feller. 25 years old.. trying to run cow calf on 80 acres...
Hummmm ?
No one has done this ?
   / swapping a gas for diesel engine, massey 65 #5
The engine is the 1st step, he'll have to change also the drive gears as the diesel will put a lot more torque on them. Unless he doesn't work it and wants as a running memory.
   / swapping a gas for diesel engine, massey 65 #6
Most tractor manufacturers now have a digital parts manual availible to browse on a dealer's website. There you can look and see if there were different transmissions, clutch disks, front axle brackets, hoods, radiators etc. for the gas vs diesel models. It may end up being a huge project if there are lots of differences between the two (besides just the engine).
I know how special such a tractor can be- I inherited my great grandfather's tractor (1943 Case SC)
I think....? Maybe. ...???
I have convinced him. To just overhaul /restore his grandpa's tractor.
That continental engine should last him the rest of his life, just take care of it.
   / swapping a gas for diesel engine, massey 65 #8
That makes the most sense. Those are good engines and can be kept running virtually forever with minimal effort.
   / swapping a gas for diesel engine, massey 65 #9
G'day not sure with a 65 but I would guess it should bolt straight up I can't see massey having different g/boxes/final drives for the 2 different engines. It would make it a cheaper engine to run and properly serviced will go for a long time. What engine has he found to go in it?
Jon
   / swapping a gas for diesel engine, massey 65 #10
Peabody,
If the gas engine is running, I too, think your friend might be better off trying to sell the tractor and applying the money to the cost of one with a diesel. If he has found a really good buy on a Pearkins, then the engine swap might be a good idea.
GManBart,
I like the word definitions you have at the end of your post. When I used a desktop, I had ones for loose and lose taped to the monitor.
2004 HYUNDAI V12530152-AJS 53FT DRY VAN TRAILER (A52141)
2004 HYUNDAI...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
UNUSED AGT QUICK ATTACH HYD DROP HAMMER (A51244)
UNUSED AGT QUICK...
2017 Caterpillar 326FL Hydraulic Excavator (A50322)
2017 Caterpillar...
Orthman 9300 4 row cultivator (A52128)
Orthman 9300 4 row...
2022 CASE TV370B SKID STEER (A51242)
2022 CASE TV370B...
