SVL CTL Improvements
/ SVL CTL Improvements
most importantly, closed center hydraulics.
I was looking at the list of all the new Caterpillar models that use Kubota engines, and I saw that the Cat min-ex's have a DPF-less solution on the Kubota engine. Any idea if the Kubota excavators will go this route?
You'd wonder why Kubota didn't do that for themselves?
/ SVL CTL Improvements #4
Kubota Tractor does not seem found of a DOC based engine system as indications are it will shorten the lifespan of the engine as it has to run at higher temperatures. Its a curious thing because the engine division builds them and the tractor division quite intentionally chooses not to use them.
OK, thanks. I guess they have their reasons?
2019 Toyota Mirai Sedan (A61574)
2019 Toyota Mirai...
2026 KH72 72in Hydraulic 4-Way Clamshell Bucket Skid Steer Attachment (A66734)
2026 KH72 72in...
2014 Kubota SVL90-2 (A64911)
2014 Kubota...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
2016 Nissan Altima Sedan (A66738)
2016 Nissan Altima...
213121 (A64276)
213121 (A64276)
