Surveying question
/ Surveying question #11
Can you find any of the nearby points? If you can, you can measure out the deed distance from the point using a compass for a rough direction. That should tell you if the post is under the beaver dam.
/ Surveying question #12
If you do it with a compass, don't forget to factor in the declination angle for the area you are in.
/ Surveying question #13
<font color=blue>...Can I plot them with a simple compass?...</font color=blue>
Sure, you can do a "rough" re-survey with a compass and tape...
Take a copy of your survey map outside and go to the closest "known" corner near the "lost" corner... lay the map on the ground and orientate it so it best matches with your approximate property lines... you can either use the compass or "eyeball" the angle... then use the tape and measure off from there... Do the same thing with the other "known" corner beyond the "lost" corner and work your way backwards to "intersect" the taped lines... this will approximate your lost corner...
The bearings serve as a means of defining the relative directions of the lines, but have little meaning by themselves. Using a compass would normally entail knowing the declination difference of magnetic north versus true north in your part of the US as most modern/current survey maps will have true north instead... that's why the "eyeball" method may be less confusing to use... though not as accurate..
Good luck on finding it... /w3tcompact/icons/smile.gif
/ Surveying question #14
Use a lawyer to set up the whole thing for you. He'll be able to do all the registration and know the local quirks entailed. He can also look after the surveying as this will ensure the surveyor has proper documentation for the job required. Also ensure any outside boundaries with other parties are defined and registered.
In short: See a lawyer and then go from there. He can look after everything. It may be expensive short term but cheap in the long run.
Egon
/ Surveying question #15
You might also request that the surveyors place survey markers every 100 feet or so if the property lines go through heavy forest. We did that back in April and were very happy we did it that way cause walking that forested lot line can be disorienting.
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
2017 Ford F-650 Mason Dump Truck (A59230)
2017 Ford F-650...
2005 Chevrolet C4500 Landscape Dump Truck (A59230)
2005 Chevrolet...
Ford Pickup Truck Bed (A59230)
Ford Pickup Truck...
2018 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A60352)
2018 Chevrolet...
2012 HEIL TRAILER INTERNATIONAL CRUDE TRAILER (A60736)
2012 HEIL TRAILER...
