Surprise Lug Nut Torque
/ Surprise Lug Nut Torque #1
MountainBuck
TN
Ventrac 4500P; Kubota RTV-X1100C
So I'm doing the 100 hr service on my 4500P and re-torque inner lug nuts sounded like a whole lotta work for no pay off.
I mean that I've heard of lug nuts on cars coming loose but it just didn't seem like it was worth the effort, but I did it anyway. I'm glad I did!
First surprise on my duals was the spacer to inner wheel was torqued way more than I would have thought. In fact my manual didn't technically say what the spacer should be torqued to when tightening on the inner lug studs. I figured 55 ft/lbs would be standard and what I torqued mine back too.
Second surprise was that the inner lug nuts. All of them needed tightening! A whole lotta tightening. Many moved more than a quarter turn.
Finally, I didn't take the spacer apart like in the manual. I loosened and re-torqued the center shaft on one but once I realized I could get to the inner lug nuts, I didn't separate them.
BTW I also didn't find any need to re-torque the steering cylinder/ front forks to the crazy 150 ft/lbs it called for. Thats more than I can pull without a cheater bar! Put my breaker bar on that and couldn't move it. Tight enough.
/ Surprise Lug Nut Torque #2
This is what the torque values are for my Kubota M6040. Inner wheel nuts - 225 ft lbs - Outer rim nuts - 180 ft lbs. Many of my lug nuts were not up to spec the first time(20 hrs) I checked them. At 20 hrs I removed all the lug nuts - one at a time - put blue thread locker on the bolt and tightened the nut to spec. Not a single nut has loosened since then.
2012 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2012 CATERPILLAR...
(APPROX. 34) 2X6X10.5 ROUGH SAWN OAK (A64276)
(APPROX. 34)...
2008 Case IH 2152 Combine Header (A63688)
2008 Case IH 2152...
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
New/Unused Wolverine 78in Quick Attach Smooth Bucket (A65583)
New/Unused...
