Surging Transmission
/ Surging Transmission #1
siman00
Lumberton NC
None
Hello all. I've searched for my issue several times, but have not found any topics that seem to relate.
I have a 2005 Kubota B2410 HST that I bought used a couple of months ago. It has 750 hours on the clock and seems to be in good condition.
My problem is that the transmission surges at slow speeds. By "surging", I mean that it will sometimes jump forward without any movement of the pedal. It seems to happen more when it is at or just above idle rpm and I'm parking it for the day. When it surges, it will rapidly move forward maybe 6 inches without any pedal input. I will be slowly inching forward, and the surge is unpredictable and dangerous.
Hydraulic fluid is full, and was changed with new filters by a dealer just before I bought it. Otherwise, the tractor behaves exactly as I would expect.
Has anyone else had this happen? Is it harmful to the tractor? What was the fix?
Any help I can get will be appreciated.
/ Surging Transmission #2
A "grabby" HST is not unheard of - there's a discussion here that sounds like similar symptoms but with different ideas about causes. Is yours more pronounced in L, M or H ?
Loose-fitting or worn pedal linkage or the damper are possibilities too, as would be contaminated fluid. Might be worth a try to change the fluid and filters again, and see if it helps. Any chance of talking with the prior owner to see if the symptoms are new or maybe not?
The 2410 has only a low and a high. It is more pronounced in high range. I'll take a look at pedal linkage to see if there's any slop in it. And I'll ask the previous owner about it, too. Thanks for the ideas.
Kubota L3901HST
Kubota L3901HST
UNUSED WOLVERINE TDB-11-72W 72" QUICK ATTACH BKT (A62131)
UNUSED WOLVERINE...
UNUSED RAYTREE RMSC78 - 78" HYD SOIL CONDITIONER (A62131)
UNUSED RAYTREE...
2021 Kubota SVL75-2 Track Loader (A63118)
2021 Kubota...
2016 Jeep Compass 4X4 SUV (A56859)
2016 Jeep Compass...
2018 New Holland C227 Compact Track Loader (A63118)
2018 New Holland...
