Surging Transmission
/ Surging Transmission #1
Mvdonisi
Franklin, Ohio
JD 110 TLB
I have a 2003 JD 110 TLB Tractor. On occasion while trying to move the machine forward or reverse it surges and jumps around like it's not getting enough fluid. Check the levels and everything is ok. The machine works fine if you use the toggle switch and lever that moves the machine while running the backhoe.
Any Thoughts
Thanks Mvdonisi
/ Surging Transmission #2
Hi. Welcome.
Could be air is getting into the system. When was the last time the fluid and filter replaced?
/ Surging Transmission #4
Was the suction line cleaned at that time? I am just throwing out possible causes.
I'm not sure the service was completed before i bought the tractor. I'll contact previous owners and ask.
Thanks
STORGE SPACE WITH MISC ITEMS (A67714)
STORGE SPACE WITH...
Unused 2024 Land Pride RCF2072 6ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2024 Land...
2017 Ford F-150 Ext. Cab Pickup Truck (A61572)
2017 Ford F-150...
Generator (A64553)
Generator (A64553)
PALLET OF PRESSURE WASHER FUEL TANKS (A68842)
PALLET OF PRESSURE...
2020 PETERBILT 367 (A65643)
2020 PETERBILT 367...
