superior loader for Jubilee
   / superior loader for Jubilee #1
alby
ford jubilee
I purchased a Superior model#H-2268 loader that was on a Ford 641 Workmaster. I was told it will work on my '53 Jubilee but I've been trying to find pictures of how it mounts to the front. I have both brackets for mounting @ rear, the bracket that holds the front drive hyd. pump & the shaft to go to the crank. Just need instructions or pictures of front mount. Any help would be appreciated.
   / superior loader for Jubilee #2
I'm not sure about the superior loader but here is the ford loader bracket. it should mount up something similar to your tractor. Can you post a photo of you front loader bracket?
Kirk
   / superior loader for Jubilee #3
Any plans to try and add power steering to your Jubilee? It will be hard to turn without it.
Thanks for the reply, but I finally figured it out & all the hardware that came with it mounted to mine o.k.
Probably sometime in the future I'll add power steering, but for now I'll tough it out!
   / superior loader for Jubilee #6
if you do add power steering, and you have a front pump, look at jackson PS, they have some diverters and orbital valve steering column replacements.
In any case, as you now know.. if it fit a 600 it fits a NAA, as long as it didn't need trans side bolt hookups, but rather rear axle and front bolster hookups.
2022 BOBCAT S64 COMPACT SKID STEER LOADER (A53473)
2022 BOBCAT S64...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
2017 Dodge Charger (A53424)
2017 Dodge Charger...
INMY Manual Landing Gear (A51692)
INMY Manual...
2009 Skeeter SL190 19ft Boat with 21ft Boat Trailer (A51694)
2009 Skeeter SL190...
1982 GOOSENECK 24FT TRAILER (A52472)
1982 GOOSENECK...
