superior loader for Jubilee
   / superior loader for Jubilee #1
alby
ford jubilee
I purchased a Superior model#H-2268 loader that was on a Ford 641 Workmaster. I was told it will work on my '53 Jubilee but I've been trying to find pictures of how it mounts to the front. I have both brackets for mounting @ rear, the bracket that holds the front drive hyd. pump & the shaft to go to the crank. Just need instructions or pictures of front mount. Any help would be appreciated.
   / superior loader for Jubilee #2
I'm not sure about the superior loader but here is the ford loader bracket. it should mount up something similar to your tractor. Can you post a photo of you front loader bracket?
Kirk
   / superior loader for Jubilee #3
Any plans to try and add power steering to your Jubilee? It will be hard to turn without it.
Thanks for the reply, but I finally figured it out & all the hardware that came with it mounted to mine o.k.
Probably sometime in the future I'll add power steering, but for now I'll tough it out!
   / superior loader for Jubilee #6
if you do add power steering, and you have a front pump, look at jackson PS, they have some diverters and orbital valve steering column replacements.
In any case, as you now know.. if it fit a 600 it fits a NAA, as long as it didn't need trans side bolt hookups, but rather rear axle and front bolster hookups.
198367 (A51243)
198367 (A51243)
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB Crane Mechanics Truck (A52377)
2015 Ford F-350...
2008 VE 500 BBL FRAC TANK (A53843)
2008 VE 500 BBL...
2002 Ford F-350 Crew Cab Flatbed Truck (A51691)
2002 Ford F-350...
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
2012 TROXELL COMPANY  130 BBL VACUUM TRAILER (A52472)
2012 TROXELL...
