Sunflowers and Deer
/ Sunflowers and Deer #1
TNhobbyfarmer
Middle Tennessee
Kubota L3430 Polaris Ranger 500
I planted around an acre and a half of sunflowers with the idea of having a dove hunt this fall. The deer have mauled those poor sunflowers to the point that very few of them will head out. Is there any way (short of erecting a 8' fence) to discourage those buggers. I think I already know the answer, but I'll throw it out there anyway for comment. There are a lot of ingenious folks out there who might have an idea.
/ Sunflowers and Deer #2
Guy I know uses CDs hanging around his garden, they move constantly and send flashes of light - he says it helps, I never tried.
/ Sunflowers and Deer #3
Strangely enough I have gone through the same senario!:mad:
You already have the answere with a fence or the playing Heavy Metal music!;)
/ Sunflowers and Deer #4
Neighbor recently strung rope around his garden about 4' high. He then tied the orange "line-mans" tape, like used in surveying for markers, about every 6'. The tape is looped over the rope so it has 2 "streamers" hanging down - if that makes sense. It's been up about 3 weeks and the deer have stopped eating his plants.
Eddie
/ Sunflowers and Deer #5
when we plant our food plots we use chicken manure on them and it helps to keep the deer away until the plants can get big enough to produce. They don't like the smell and it takes a few weeks for it to go away.
/ Sunflowers and Deer #6
An ample dose of lead poisoning is the only thing I've found that works. And, it's limited in effectiveness. In dry years like we've been having, much of the green stuff in the woods gets tough. That makes those succulent sunflower, peas, beans, rose bushes, etc. look that much better to the deer.
There are all kinds of things you can try.. The CD's or pie pans hanging around, rope/tape around plot, human hair from the barber shop scattered across plot, etc. are all common techniques. Most work for a little while, then the deer get used to it and return to their nightly snack. The most effective solution I've seen was used by a fellow just down the road from me. He plants purplehull peas every year and stakes a hound at each end of the plot. Even with the dogs there, the deer soon learn that as long as they stay out of reach of the dogs, they can eat all they want. They just have to put up with the constant barking of the dogs. Of course using this technique involves daily food/water for the dogs, so that may not be an attractive solution.
Good luck,
BR
/ Sunflowers and Deer #7
had the same problem last year with lab-lab. the deer would eat it before it got mature enough to stand the browsing.this year i put up a temporary electric fence. i bought 12 volt charger because i had a couple of deep cycle batteries and the 12 volt charger was cheaper than solar charger. i think you could fence 2 acres for less than 150.00 4 t posts 24 small metal electric fence posts, small roll wire 1 ground post, plastic fence clips, fence charger. i used single strand set up and the deer did break the wire twice in 6 weeks.took the fence down last week,diidn't save the wire but will be able to use the posts next year.
/ Sunflowers and Deer #8
Do a search for Plotsaver. It looks like a cloth ribbon that gets put up like a rope fence and is sprayed with some sort of deer repelant. My neighbor uses it and it works.
/ Sunflowers and Deer #9
Must be something to do with the available food supply or the type of deer. Around here the Mule deer don't touch my sunflowers. I've got thousands of them and the deer haven't touched them "yet". They didn't touch them last year either.
I think the lead poisoning suggestion is the only one that is economically viable. Everything else is expensive and not that reliable.
PB
/ Sunflowers and Deer #10
I haven't tried it myself, but have been told that one way of keeping deer out is to run a double electric fence. You make a fence about 3' high around the perimeter of the area you wish to protect. Then place another fence as high as you can get it, about 4' in from the first.
The concept is that the first fence is too low for them to get under, the second fence is too high to jump over and they are too close for the deer to clear. Deer can either go straight up or clear a long distance, but don't seem to do both at once. I hope my description is understandable.
One thing to consider is that deer have trouble seeing the regular electric fence wire, so you might want to consider the ribbon fence wire that is sold for horses.
BTW - lead poisoning is the surest way to keep them away.
/ Sunflowers and Deer #11
I plant lots of food plots on our ranch and one of the ingredients in the mix that I'm using is Sun Flowers they are the larger variety but the deer love em if you do a search on Sun Flowers you'll find a bunch of info on planting them for wildlife although mostly for birds the deer still mow thru them pretty quick. I realize your trying to keep the deer out not feed em but the point is they are a good attractant for them, we also planted some in our garden to harvest the seeds they are behind a 4 wire electric fence but its only 4 feet high and so far this is the second year and its keeping them out as well as the rabbits since the bottom wire is at 6". Electric fence is a good alternative to keeping deer out but if you add a good sized dog to the equation it works 100% without the dog the deer or at leaset a good portion of them will quickly learn how to get around, over or thru it if the attraction is great enough for them.
Steve
Went to the farm today. Things are now looking a little better. I'm guessing about a third of the sunflowers have headed out. I guess the deer didn't get to them all, at least not enough to prevent some of them from blooming. Maybe I'll have a good enough survival rate to attract some doves.
/ Sunflowers and Deer #14
The road in front of my place acts as a deer herd thinner. Cars get at least three a year if not more.
My neighbors have a very large garden/orchard area and the only thing I have seen them use is fence on the timber side of the property with white cloth strands tied to the fence. I have not heard them complain about deer damage.
My garden area is surrounded by cyclone fence and so far this has kept all critters, except for a few bugs, away from my plants.
Farwell
1995 CHEVROLET KODIAK C7500(INOPERABLE) (A67714)
1995 CHEVROLET...
2015 Chevrolet Silverado 2500HD Crew Cab Knapheide Service Truck (A68183)
2015 Chevrolet...
PVC PIPE FITTINGS (A64276)
PVC PIPE FITTINGS...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
KAWASAKI 95ZIII Radiator (A68134)
KAWASAKI 95ZIII...
2024 Unused Land Pride PF1242 42. Forks and Frame Skid Steer Attachment (A66734)
2024 Unused Land...
