Sun canopy for ck2610
   / Sun canopy for ck2610 #12
If you ever expect to work around trees I would recommend steel, aluminum, or a wood DIY canopy; definitely not fiberglass.
   / Sun canopy for ck2610 #15
I bought a 9' patio umbrella (for $20 on clearance), plan on strapping a PVC pipe on the ROPS of the M4700 and sticking it in the pipe. Easily removable for when I go where it's dense, which is most of the time.
I've got a metal canopy for it but took it off for the drive from Virginia to Mississippi and it doesn't seem worth putting back on.
When I bought the M4700: 8x6SAM_0797.jpg
Where it works:IMG_20151207_150524186_HDR.jpg
   / Sun canopy for ck2610 #16
Because it would be more durable or because it would better resist penetration from a falling dead branch? Or?
I worry a lot about branches falling from dead trees, etc when they get hit.
   / Sun canopy for ck2610 #17
Durable. Fiberglass is rigid but brittle. My steel canopy has some new bends from trees but still does the job (and can be straightened if I cared enough). Some of the flexible plastic materials might be OK (durability-wise) with a good frame. I am skeptical about the quick on/off option unless the canopy is very light. My metal canopy weighs about 100 lb and there was nothing quick about installing it. I have no concerns about falling dead branches but a whole tree would crush the canopy (but perhaps spare me).
By the way, with the canopy cantilevered on the ROPS it puts a lot of force on the ROPS (pulling it forward) and makes creaking sounds on uneven ground. My ROPS is pivoted at the base and I had to switch to harder adjusting bolts (and hardened plates) because the OE bolts were too soft and the ends were mushrooming. I am considering adding front struts to better support the canopy.
   / Sun canopy for ck2610 #18
I hit tree limbs with the canopy on my mower all the time. I really should take a chainsaw to them but that would be a weeks work for the amount I’m dealing with. I wouldn’t even consider anything that’s breakable.
   / Sun canopy for ck2610 #19
What was the price on the Kioti canopy?
My dealer gets $450 out the door for them. Fiberglass or Diamond Deck Aluminum. Either or.
   / Sun canopy for ck2610 #20
2019 INTERNATIONAL RH613 (A58214)
2019 INTERNATIONAL...
2006 Ford F-750 Hazardous Material Truck (A56858)
2006 Ford F-750...
TPM 10 Piece Mini Excavator Heavy Duty Attachment Set (New/Unused) (A59225)
TPM 10 Piece Mini...
2013 PETERBILT 389 (INOPERABLE) (A55745)
2013 PETERBILT 389...
2017 COTTRELL TRAILER (A55788)
2017 COTTRELL...
JOHN DEERE 6115D TRACTOR (A58375)
JOHN DEERE 6115D...
