Ballast Suitcase weights
/ Suitcase weights #1
Anonymous Poster
Epic Contributor
Anyone know where I can get suitcase weights for my YM1300D? I am currently using two IH weights but they are only on loan and are too big and don't fit right.
Thanks
Hondo
/ Suitcase weights #2
Your location would help us help you. Freight is a killer.
/ Suitcase weights #3
I use the ones I bought at John Deere. About $40 for 40 pounds of weight, hook over the front bumper on my YM 1700.
/ Suitcase weights
I am in Rochester, NY 14624. Freight probably would cost more than the weights huh? Let me know. Thanks.
/forums/images/graemlins/cool.gif
/ Suitcase weights
People have done all sorts of things for weights-- I've seen discussions about getting used weightlifting weights at yard sales and making up a bar to hang them on or using cement with rebar to hang on the front. No sense in paying for a custom made item when all you need is something heavy.
/ Suitcase weights #6
the jd quick attach weights (something like that) weights for the 4000 series are the same used on the yanmar.. at least the one's i got from a yanmar dealer fit's my neighbors jd and my hinomoto nicely.. #42 paid 35 a piece..
/ Suitcase weights #7
IS there any reason to ever take the weights off? If yes, the the JD weights may be worth it for ease of removal. If no, just bolt on a series of 4" pvc pipes with rebar and concrete in them. That should add weight fast. bw
/ Suitcase weights #8
As some else stated. check another dealer.. I got some suitcase weights from a NH dealer.. and yes.. like a buck a pound or so... also fit great on my ym1700.
Also made a front bumper extension out of a couple lengths of some large diameter pipe filled with concrete ant rebar. That and the 2 suitcase weights mad ethe 30" dirt scoop real effective.
Soundguy
/ Suitcase weights
I looked around for weights but had no luck. I welded up some plate steel into a box and filled it with cement. It weighs in at 170 but looks like s*#t. Maybe I'm in the minority but I like my stuff to look nice as well as function nice. Wall Mart has 25# plates for 10 bucks. I plan on making a bracket that will bolt to the front bumper and the plates will slide on one at a time. Easy on - easy off. I figure why leave the weights on when you don't need them.
/ Suitcase weights #10
What are these 25# plates for $10 at WalMart? Are they those round weight set weights with a hole in the middle?
/ Suitcase weights
Yes, regular weight lifting, barbell weights, whatever.
/ Suitcase weights #12
Since I don't plan to remove my weights on a regular basis, I found a good-sized ammo can at the local Army/Navy store. I drilled four holes to match the bumper holes, ran 4 carriage bolts(with large washers) through, filled the can with about 100+ lbs. of used lead wheel weights and concrete. I let the concrete cure, painted it Rustoleum spruce green to match the Yanmar green chassis, and bolted it on. It isn't as nice as suitcase weights, but it's better than some other ideas I've tried..and much heavier than concrete alone!
/ Suitcase weights #13
Just a word of advise.
I was planning on fabricating my own front weights to save a few bucks. After rolling my TLB over this past weekend, finding myself upside down with the machine resting on the ROPS, dangling from the seatbelt staring at where the weights would have been located, and possibly fallen off of. I'm now rethinking my homegrown ideas to include a better way to semi-permanently bolt the weights in place to keep them from ever coming loose, and causing injury or some other damage. All factory suit case weights will have some sort of chain or bar holding them firmly in place. You just can't be too careful.
Jim
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
2004 International 8600 Tender Truck (A63688)
2004 International...
2022 EZ-GO ELITE...
Sterling AT (A63689)
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
