Suggestions for a pressure tester
   / Suggestions for a pressure tester #1
BeezFun
IL
Kubota B2710
It's too cold to do anything outside, so I want to make a pressure tester. I'm thinking a T fitting with a female quick disconnect, a male QD, and a 5000psi pressure gauge. Before I do this, any handy tips on how to make it better or more useful.
   / Suggestions for a pressure tester #2
5000 psi?
Make damn sure that every part is capable of handling that pressure. Unlike hydraulics, air causes explosions!
   / Suggestions for a pressure tester #3
One can almost buy one for same price as ordering all the parts and assembling it oneself...
   / Suggestions for a pressure tester #4
Your thinking is what I did, but I used a 4000psi gauge:
The view of relief pressure from the V417 seat:
I'll look into that, the hose might not be a bad idea to make it easier to hook up.
   / Suggestions for a pressure tester #6
At least with hose you can move gauge amount to here you can look at it from various positions.... Might be a real convince of you are adjusting pressure and you can actually have gauge facing you when actuating a control...
If you are constantly monitoring something it may be ok for a gauge on "T" connection.... But if just occasional check or adjust its ok to "deadhead" a control long enough to get a reading... Just being able to plug into a hydraulic line to FEL momentarily may be enough to test system...
   / Suggestions for a pressure tester #7
If you use a hose run it from the tee to the gauge so you can monitor the working pressure.
I can see the pressure on the brush hog, 500 psi in grass, goes up over 1000 in brush:
   / Suggestions for a pressure tester #8
Hyd gauges are most accurate in the middle of the scale, I like 5000psi for most systems but add a quick connect to change guages.
   / Suggestions for a pressure tester #9
I'd use a hose in conjunction with a gauge AND both the male and female QD. Then you can use it inline as well as for deadheading a circuit.
   / Suggestions for a pressure tester #10
I use a Stant pressure tester ... screws right on to the expansion tank , it seems they were made for our cars
2018 John Deere 310L 4x4 Extendahoe Loader Backhoe (A52377)
2018 John Deere...
2013 INTERNATIONAL MA025 ROUSTABOUT (A52472)
2013 INTERNATIONAL...
2014 Ford Explorer AWD SUV (A51694)
2014 Ford Explorer...
New/Unused CFG Industrial MX15 RX Mini Excavator (A51573)
New/Unused CFG...
2016 John Deere 5055E 55HP Utility Tractor (A52377)
2016 John Deere...
