Suggestions for a pressure tester
   / Suggestions for a pressure tester #1
BeezFun
IL
Kubota B2710
It's too cold to do anything outside, so I want to make a pressure tester. I'm thinking a T fitting with a female quick disconnect, a male QD, and a 5000psi pressure gauge. Before I do this, any handy tips on how to make it better or more useful.
   / Suggestions for a pressure tester #2
5000 psi?
Make damn sure that every part is capable of handling that pressure. Unlike hydraulics, air causes explosions!
   / Suggestions for a pressure tester #3
One can almost buy one for same price as ordering all the parts and assembling it oneself...
   / Suggestions for a pressure tester #4
Your thinking is what I did, but I used a 4000psi gauge:
The view of relief pressure from the V417 seat:
I'll look into that, the hose might not be a bad idea to make it easier to hook up.
   / Suggestions for a pressure tester #6
At least with hose you can move gauge amount to here you can look at it from various positions.... Might be a real convince of you are adjusting pressure and you can actually have gauge facing you when actuating a control...
If you are constantly monitoring something it may be ok for a gauge on "T" connection.... But if just occasional check or adjust its ok to "deadhead" a control long enough to get a reading... Just being able to plug into a hydraulic line to FEL momentarily may be enough to test system...
   / Suggestions for a pressure tester #7
If you use a hose run it from the tee to the gauge so you can monitor the working pressure.
I can see the pressure on the brush hog, 500 psi in grass, goes up over 1000 in brush:
   / Suggestions for a pressure tester #8
Hyd gauges are most accurate in the middle of the scale, I like 5000psi for most systems but add a quick connect to change guages.
   / Suggestions for a pressure tester #9
I'd use a hose in conjunction with a gauge AND both the male and female QD. Then you can use it inline as well as for deadheading a circuit.
   / Suggestions for a pressure tester #10
I use a Stant pressure tester ... screws right on to the expansion tank , it seems they were made for our cars
(9) 2 PLUG VALVES (A52472)
(9) 2 PLUG VALVES...
New Land Honor 5400 LB Ratchet Binder And Chains (A53002)
New Land Honor...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
New/Unused 7ft Stainless Steel Work Bench with 20 Drawers (A51573)
New/Unused 7ft...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2020 MACK GRANITE TRI AXLE DUMP TRUCK (A52576)
2020 MACK GRANITE...
