Sudden power loss CT225
   / Sudden power loss CT225 #1
bbse
Platinum Member
Nashville, TN
Mahindra 3325
I was brush cutting today, it was hotter than the gates of Hades BTW, I was stopping every hour to clean the grill, temp gauge never went more than 2 dots over normal. Anyways, after about five hours mowing it just lost RPM and nearly stalled. I was not cutting at the time but turning on cut grass. I thought it might be a fluke and maybe I just had hit a big clump but it did it again. No missing or sputtering, just acts like it wants to die.....which it eventually did. Let it set a moment and restarted, it revved slowly but as long as I did not put a load on it it ran OK. Tried to cut some more and Bam, no power. I put her on the trailer and took her home. Will check fuel filter and air filter in a bit, have a heat stroke at the moment....man it is hot today. Fuel and air filters were changed at 50 hours, oil and filter at 50 and 150. Currently at 170 hours.
Update: After recovering from the heat, I checked the air and fuel filters, turns out the fuel filter bowl was about empty. I switched the lever to the Air setting and started her up. The fuel bowl filled back up. I have to assume it was the problem as the heat must have caused some type of vapor lock. I have never had this happen before even though I have cut in severe heat before with several different tractors. I hope this is all it was anyways.
   / Sudden power loss CT225 #2
If this happens again, loosen your fuel cap up and see if it recovers.
Thanks Rick,
For a 2nd Update:
Went to fill her up this morning from a full 6 gallon can that I overfill to about 6.5 gallons. The gauge was on a 1/4 tank so I usually only have to put in around 5 gallons. It took the whole can and was still a gallon or so shy from being full. I think the gauge is lying to me and when I got off of level I was running out of gas. I am taking it to the dealer next week or two for a few last minute warranty fixes before the bumper to bumper runs out. I will have them check the gauge.
   / Sudden power loss CT225 #4
Something on the sendor may be hanging, not letting it drop to bottom, but my Ct225 is just opposite. I run until guage shows all way to empty, run another 1 or so then put in 5 gallons and most of the time will overflow tank getting the last of can empty.
   / Sudden power loss CT225 #5
I have a 225 and the gas guage is fickle. It reads ok until low, but may or may not work when refilled. It takes it's own sweet time.
   / Sudden power loss CT225 #6
The fuel guages are nothing like a car. Mine would stay on full for ever and at "E", it was dry. Sometimes, it would hang up as mentioned. I took out the sending unit, adjusted the float arm. Now at "E", I have about 2 1/2 gallons left which lets me empty my five gallon container into the tank.
I second Wallace's suggestion. The fuel cap doesn't seem to be letting air into the tank unless you were truely on fumes.
   / Sudden power loss CT225 #7
Vic,
That's exactly how my gauge works. I'm good with that too. Reads empty and takes 5.5 gallons to fill. I prefer it that way. But, then again I'm only using about 15 gallons a year right now. If I were a field user, where I might be far from the can, I'd want it to be more accurate.
KBH 25 TON TENDER (A56438)
KBH 25 TON TENDER...
2025 Chevrolet Malibu (A59213)
2025 Chevrolet...
2003 Caterpillar 416D (A57148)
2003 Caterpillar...
UNUSED FUTURE HLS25 HYD HORIZONTAL LOG SPLITTER (A58376)
UNUSED FUTURE...
Metal Sunflower Spinner (A57454)
Metal Sunflower...
2011 Chevrolet Silverado 2500 Pickup Truck, 127808 Miles, Utility Rack - GREAT WORK TRUCK (A56438)
2011 Chevrolet...
