bbse
Platinum Member
I was brush cutting today, it was hotter than the gates of Hades BTW, I was stopping every hour to clean the grill, temp gauge never went more than 2 dots over normal. Anyways, after about five hours mowing it just lost RPM and nearly stalled. I was not cutting at the time but turning on cut grass. I thought it might be a fluke and maybe I just had hit a big clump but it did it again. No missing or sputtering, just acts like it wants to die.....which it eventually did. Let it set a moment and restarted, it revved slowly but as long as I did not put a load on it it ran OK. Tried to cut some more and Bam, no power. I put her on the trailer and took her home. Will check fuel filter and air filter in a bit, have a heat stroke at the moment....man it is hot today. Fuel and air filters were changed at 50 hours, oil and filter at 50 and 150. Currently at 170 hours.
Update: After recovering from the heat, I checked the air and fuel filters, turns out the fuel filter bowl was about empty. I switched the lever to the Air setting and started her up. The fuel bowl filled back up. I have to assume it was the problem as the heat must have caused some type of vapor lock. I have never had this happen before even though I have cut in severe heat before with several different tractors. I hope this is all it was anyways.
