sudden engine stop B2650
/ sudden engine stop B2650 #1
gravelman
Platinum Member
NH
Kubota 2650
My Kubota B2650, 2016 year suddenly shut down while driving along. Still have ignition redlight and glow plug light on dash, nothing else lights up I checked fuses and as many connections as ii could see/reach, all look ok. Will not turn over either. Any suggestions?? No i am not a mechanic... thanks all
/ sudden engine stop B2650 #2
check and make sure your battery cables are still tight, but not be allowing enough amps through if they are loose.
battery connections are tight, good thought tho
WILL DO THAT...thanks... and will report back
all switches seem to be fine....no cut wires, no pto on, hd in neutral etc. i have had safety switch problems in the past but the dash board sill lit up , dash board does NOT light up now. Just the little red light for ignition and glow plug if i move to that. I hear no clicking, nothing. Has to be electrical im guessing.
/ sudden engine stop B2650 #8
Mine will die if I lift up off the seat. That would be what I would work first. And it may be a status indicator for that stuff. Good luck sir and you will find it
ok on that... i got no dashboard lights or indicators... that has never happened before
/ sudden engine stop B2650 #10
You have definitely lost it somewhere. Wiring is really solid on these machines. I feel sure you have already bugun the fuse checking process and I hope you find the culprit there. You know there are some circuit boards that process the inputs to the out puts, and I hope the problem isn’t there because they are costly.
/ sudden engine stop B2650 #11
If original battery, try boosting it, or remove battery and have it “load tested” at any garage…
However my guess is a battery cable, especially the ground cable. Remove both ends and clean post and frame with sandpaper. When reattaching apply dielectric grease at each end and then fasten securely. Keep us posted…
i came to a dead end as i am not a mechanic...i have a service company coming this week. Fingers crossed. I also don't think it can be towed??? Maybe a short pull on a flatbed if they need to bring it to the shop Thanks for all the suggestions and you are right...i have had very few problems with this machine.
Battery is fine...all lights , heater, ac work fine. I checked the connections, all clean and tight. Im convinced it is electrical and a breaker or fuse.
update... my tractor has Operator Presence Control system (OPC) in other words safety shut offs. Anyhow, that 5 amp fuse was blown for that system....and it blew after applying the parking brake. Have not gone looking yet for where a wire is being scuffed or what is causing the fuse to go out but it has something to do with setting the brake and not a general wiring problem. More later
Anco 3Pt Ditcher (A66408)
Anco 3Pt Ditcher...
3pt Tractor Weight Set (A64127)
3pt Tractor Weight...
New/Unused 7ft Double Chain Sling (A65583)
New/Unused 7ft...
SDLanch SDLGC80 (A64127)
SDLanch SDLGC80...
2019 LAYMOR SM300 RIDE-ON SWEEPER (A65053)
2019 LAYMOR SM300...
Miller Millermatic 212 Auto-Set MIG welder (A63689)
Miller Millermatic...
