suction line
/ suction line #1
Garrabo
Banned
GA
3120,X-575,BX1830,BX22
whats the best way to get at the transmission strainer,-suction line on a BX-22. do you have to remove the rear wheel. I have almost 200 hrs.
thanks
/ suction line
will I need to remove the backhoe?
/ suction line #4
Nope, You can remove it with the backhoe on. Just rotate it out of the way.
/ suction line
I think I have spotted the strainer, do I need to remove the rear wheel, If its the plug I think it is I cant see any other way to get to it. If I raise the tractor with the outrigger to remove the wheel, will the tractor drop when I remove the
strainer plug.. I didnt clean the strainer at 50 hrs, will i loose alot of fluid when I pull it out.
thanks
/ suction line #6
No, you do not have to remove rear wheel to remove strainer. I cleaned mine at 50 hours and it was bad, but I never tried removing the plug with hyd fluid still in there. I drained hyd fluid first, removed filter and then removed plug. Good question though. I would say it will all drain out but that is me.
/ suction line #7
When I did my BX22, I removed the rear wheel to make it easier. The 26 mm hex head was really frozen and painted over, so I needed all the elbow room I could get. BTW, removing the rear wheel was a snap. With a jack stand under the axle, I had plenty of room to work ...plus it allowed me to position my rather wide oil drain pan under the tranny. Sometimes trying to save time has the opposite effect.
/ suction line #8
bellweather-Where in Western mass do you live?
/ suction line #9
It took me some searching to find the plug. But a 1/2 drive socket and long handle fit to break it loose. To identify it, kneel at the left rear and follow the pipe up - it should go to a hose (at least on my BX-22). The strainer is long, but will come out by sliding it into the wheel space. Taking the wheel off is probably a good idea though, so you can look in. My strainer was very clean - only a few tiny bits. I too think all the fluid is history if you pull it without draining. Why not clean your drain pan(s) and just put it back after?
/ suction line #10
Southern Berkshire County
/ suction line
thanks for all the info, I guess I will do another tranny fluid change.
2018 JOHN DEERE 325G SKID STEER (A65056)
2018 JOHN DEERE...
Caterpillar 3400 Series Diesel Generator (A66734)
Caterpillar 3400...
Komatsu PC138USLC Excavator (A64047)
Komatsu PC138USLC...
2012 MERTZ ART. ARM MANIFOLD TRAILER (A67714)
2012 MERTZ ART...
Sullair 375 CFM Mobile Air Compressor (A68134)
Sullair 375 CFM...
2014 Forest River XLR Thunderbolt 40X12HP 40ft. Tri Axle 5th Wheel Toy Hauler Travel Trailer (A66738)
2014 Forest River...
