Suck oil filler cap Allis B
   / Suck oil filler cap Allis B #1
MARKallisb
The oil cap will rotate but will not come off. The tractor is a 1939 Allis B. I'm wondering what could be holding it on as I thought is was just pressed on. Regards, Mark
   / Suck oil filler cap Allis B #2
Maybe the flat spring fingers are rusted to the filler neck, if the engine hasn't been run in a while. I'd turn the cap lightly clockwise to see if it tightens a screw/nut so you don't lose it down into the valve chamber. I don't know if these are riveted or have a stove bolt. I'd tap the thing down lightly with a hammer and block. THen try to pry straight up with something that will catch both sides of the cap at once - should break free.
If not, pry harder, after finding a replacement cap first. I think this should come straight off like you said, so I'm guessing it just stuck a little.
Jim
2007 PETERBILT 335 FUEL & LUBE TRUCK (A51406)
2007 PETERBILT 335...
2014 INTERNATIONAL PROSTAR SLEEPER (A53426)
2014 INTERNATIONAL...
2019 FORD F-150 XL TRUCK (A51406)
2019 FORD F-150 XL...
2019 VOLVO TRUCK VNL (A53843)
2019 VOLVO TRUCK...
2014 Ford F-450 Altec AT200A 30ft Bucket Truck (A51692)
2014 Ford F-450...
Hyster H225E (A47384)
