Suck oil filler cap Allis B
   / Suck oil filler cap Allis B #1
MARKallisb
The oil cap will rotate but will not come off. The tractor is a 1939 Allis B. I'm wondering what could be holding it on as I thought is was just pressed on. Regards, Mark
   / Suck oil filler cap Allis B #2
Maybe the flat spring fingers are rusted to the filler neck, if the engine hasn't been run in a while. I'd turn the cap lightly clockwise to see if it tightens a screw/nut so you don't lose it down into the valve chamber. I don't know if these are riveted or have a stove bolt. I'd tap the thing down lightly with a hammer and block. THen try to pry straight up with something that will catch both sides of the cap at once - should break free.
If not, pry harder, after finding a replacement cap first. I think this should come straight off like you said, so I'm guessing it just stuck a little.
Jim
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A53473)
Michelin CARGOXBIB...
2015 Ford F-450 Knapheide Service Truck (A51692)
2015 Ford F-450...
2025 Mower King SSRC (A50123)
2025 Mower King...
Unused 2025 Spirit Electric Mini Golf Cart (A51694)
Unused 2025 Spirit...
2025 Star EV Capella 2+2 Electric Cart (A51694)
2025 Star EV...
400' Spool of 5/8"/16mm Crane Cable, New  (A52384)
400' Spool of...
