Suck oil filler cap Allis B
   / Suck oil filler cap Allis B #1
MARKallisb
The oil cap will rotate but will not come off. The tractor is a 1939 Allis B. I'm wondering what could be holding it on as I thought is was just pressed on. Regards, Mark
   / Suck oil filler cap Allis B #2
Maybe the flat spring fingers are rusted to the filler neck, if the engine hasn't been run in a while. I'd turn the cap lightly clockwise to see if it tightens a screw/nut so you don't lose it down into the valve chamber. I don't know if these are riveted or have a stove bolt. I'd tap the thing down lightly with a hammer and block. THen try to pry straight up with something that will catch both sides of the cap at once - should break free.
If not, pry harder, after finding a replacement cap first. I think this should come straight off like you said, so I'm guessing it just stuck a little.
Jim
2018 KENWORTH T880 (A53843)
2018 KENWORTH T880...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
2010 LONE STAR TRAILER MFG. GOOSENECK TRAILER (A53843)
2010 LONE STAR...
CAT Skid Steer (A50322)
CAT Skid Steer...
2016 JOHN DEERE 3032E LOT NUMBER 94 (A53084)
2016 JOHN DEERE...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
