Subsoiler/middle buster/pipe(wire) layer..
   / Subsoiler/middle buster/pipe(wire) layer.. #1
hunt4570
Elite Member
South Carolina
Grand L3540 ,724 loader, bucket, grapple and now forks also! And just for OP.. a pool!
So I'm looking to run some electrical wire (and someday some waterpipe probably) out in my yard. My soil here is mostly sand did a search and came up with the subsoiler/pipe layer combo at Agrisupply (see below).
My thought was maybe a middle buster/subsoiler combo but cant seem to find one.. What do you think of the set up below.. should it work? I like that the subsoiler is shear bolt protected just in case.
Any thoughts to these attachments? Anyone actually have them and tried them?
Subsoiler: 3 Point Subsoiler-Subsoiler Attachment | Agri Supply #73410
Pipe layer : 3 Point Pipelayer-Pipe Layer Attachment | Agri Supply #73622
I replied to this because I couldn't even find the post..
   / Subsoiler/middle buster/pipe(wire) layer.. #3
These weren't available several years ago so I made my own out of a factory bend piece of conduit, basically mounted like theirs. Made some brackets to hold a reel of wire. Not pretty but worked.
   / Subsoiler/middle buster/pipe(wire) layer.. #4
I just made one too. I think they will all work well for wire. But with a small tractor I don't thin I would trust one to get waterline deep enough.
   / Subsoiler/middle buster/pipe(wire) layer.. #5
I bought one and it was too large to attach to a standard size subsoiler but made a good beverage holder in the man cave.
I made up a smaller version with exhaust pipe flared and welded in a "V" of angle iron. Worked good for cable lines. In the picture there is a ditching point on the subsoiler, I use the standard point when burying cable. Good luck!
   / Subsoiler/middle buster/pipe(wire) layer.. #6
Howse makes a combo subsoiler/middlebuster, of which I have one. I've used the middlebuster several times, but have not yet put the subsoiler blade on. Subsoiler Middlebuster Combination
I've been thinking about rigging a conduit to lay pipe too, but haven't gotten around to it yet.
On one of the reviews I read, the guy says it will work with the small 8" middlebuster blade. I think I'm going to give it all a try.
   / Subsoiler/middle buster/pipe(wire) layer.. #8
I made my own with a 1" piece of pipe that I bent and welded to an old subsoiler that I don't use any more. It worked well for shallow burying antenna ground wires (#14 THHN ham radio antenna). I do not think it would put anything down deep however in our clay soil.
   / Subsoiler/middle buster/pipe(wire) layer.. #9
I have used a sub soil for sprinkler wire (low voltage) but these attachments won't run deep enough for higher voltage wire. Most electrical codes I have seen require that you place the wire 24" deep.
So last night I ordered the subsoiler. wire/pipe layer, and the middlebuster blade to go with.. They called this morning to tell me they were out of stock till the middle of next month..on the hunt again I guess.
BUYERS PREMIUM & PAYMENT TERMS (A51222)
BUYERS PREMIUM &...
2018 Hyundai Elantra Sedan (A48082)
2018 Hyundai...
2016 Ford Taurus AWD Sedan (A48082)
2016 Ford Taurus...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A51039)
Kubota 24in Quick...
2012 PETERBILT 388 SLEEPER TRUCK (A51222)
2012 PETERBILT 388...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2018 FREIGHTLINER...
