Attono:
the PEX will need a large rim to UNROLL into the hole a simple axle will work for most of the stuff but PEX will KINK if it is not unrolled correctly. make up a 3 or more spoke rim that will fit inside the ID of the PEX and use some sort of side plates to keep it un-spooling as if you were rolling it across the yard. The UF will work better this way as well but it can twist more than the PEX so having it pull out of a box is not as bad as the PEX would be.
One other thing is for underground I would not use PEX it should be PEX-AL-PEX or the underground rated black poly type materials.
Mark
Can you please elaborate on this a little. I was under the impression that PEX was rated for underground burial.
For the water, I'll come out from under the house, go about 20' and then do a T. Left for about 300' to get to the barn and then right to go about 250' to get to the pasture tank where I'll T again and then another 200' to get to the coop.
For the cost of an extra 20ft of tubing, I'd put the first T under the house where you can get to it... less buried junctions is better. I sure wish the previous owner of my property had thought that way!
That's not funny, by the way. I just googled Tylene while sitting at work...
Found this subsoiler on Craigslist listed as a "1 row planter". Talked them down to $80. $20 worth of exhaust pipe from Autozone and I am hope to bury about 750' of 3/4 pex and about 500' of 12/2 UF with it. I will let you know how it works.
I tied the zaust pipe trick and it did not work for me....
Plow'n in pipe - Ford Forum - Yesterday's Tractors
PEX will carry water from the house to the horse water tanks and chicken coop. 1 at the barn, 1 in the pasture, and the coop. 12/2 is for lighting to a flag pole light, automatic gate, tank heater, and chicken coop. I'll use 2 different circuits for the electrical.
For the 12/2, I'll come out with both ckts, go right into a junction box above grade with both circuits, then I'll take one and go forward about 30' to my flagpole and then on out to the end of the driveway for the gate. The other circuit will come out, go to the right to the pasture tank where I'll pull it to another junction box above grade and then carry it on to the coop. I'll get power for the barn tank from the barn.
Just got really tired of carrying water last winter.
