Submersible well pump recs please
   / Submersible well pump recs please #11
A variable speed controller is a frequency varying switching power supply. The motor in the well is generally a three phase and quite smooth. The down side is the price of that controller. They are not readily repairable and I know of no source for rebuilt controllers. Since my old pump was still working well after twenty seven years I went with the standard single phase motor and controller again. I can replace my whole controller for about $300 to $350 for a Franklin. A similar switching power supply type controller could run ten times that. I doubt I'll live long enough to see another failure - other than the occasional capacitor swap in my controller.
If you just put a new pump in, it is a good time to check how many ohms between the wires and write it down.
I think the Franklin installation manual shows how and has a place to write them down. It makes trouble shooting a little easier in the future. If you have an ammeter you should check and record the Amp draw also.
   / Submersible well pump recs please #12
I think I paid $1500 for my controller about 6 years ago
   / Submersible well pump recs please #13
I don’t know the brand of my pump. My well pump is sitting at 680’. It’s a 1.5 hp, pumping 10 gpm. We put check valves on the pipe every 40’ so the pipe is charged at all times. One of the key components of my system that I recommend is a variable speed controller. This allows the pump to turn slowly when there isn’t much demand, like a single sink faucet, or faster as demand increases such as lawn sprinklers. My well service guy told me this greatly reduces wear on the pump and reduces energy use.
That is a bunch too many check valves. Every 140-ft is probably better. And every 200-ft would probably be even better.
The probability of failure of a mechanical system is an exponential function of the number of moving parts. So, you try to limit how many things that move you put in things.
The check valve are designed for 60 to 100-psi. 60-psi is 138-ft of water head.
We had a well pump on an irrigation system that was making a terrible noise for about five minutes and then it would go away for a bit and come back. The check valve installed 40-ft down, just above the pump and failed and the flapper had migrated up and gotten stuck in the pitiless adapter. As teh pump pushed water past it it made a terrible racket. Then stopped when the flow to the pump stopped. The pump would run until it filled the three pressure tanks, and shut off, the pressure tanks drained past the broken check valve and the pump would restart. And teh it stopped making noise. Because the water flowing backwards, spun the impellers of the shaft.
Had to pull and replace the pump, which is when we discovered he cause of he noise.
   / Submersible well pump recs please #14
Is it a 3" or 4" well? I always heard the Grunfos was the best pump for a 3" well. I had a 2HP, 3 wire Franklin that my contractor burned up for me and I replaced it with a 1.5 HP Franklin. I would never have a 3 wire pump again.
   / Submersible well pump recs please #15
So far it is working well. When it stops, the well guy will need to come pull pipe. I can’t pull 680’
Why not a 3 wire?
After reading about 2 wire vs 3 wire submersible well pumps I would still stick with my decision to put in a 3 wire pump. This is for a 1.5 HP or less motor. I originally made the decision to put in a 3 wire pump 20 some odd years ago for reasons detailed below. One reason was because a 2 wire pump would need to have the starting components down in the well casing.
Since the motors I am talking about are single phase motors they need some sort of phase shifting arrangement to get the motor spinning. There are several ways to do this. A starting winding can be used which is then switched out of the circuit once the motor is spinning at about 80% of operating speed. A starting winding plus a capacitor can also be used and once again is switched out of the circuit once the RPM is high enough. The added capacitor increases the starting torque. Another scheme is to use a capacitor that is always in circuit. But then the starting torque will be lower, maybe lower than running torque. No matter which way the single phase motor is started extra components that are part of the motor and pump assembly are down the hole and if they fail the whole assembly must be pulled up and replaced. These extra components are a switch and a capacitor. There may be just a switch, a switch and a capacitor, or just a capacitor.
A 3 wire motor operates exactly the same as a 2 wire motor. The only difference is that the phase switching components are above ground. This means that if they fail they can be replaced without pulling up and replacing the whole pump. The pump motor will still have a starting winding. But this winding is connected above ground to the easily serviced and dry starting components. I cannot imagine, for me, putting the starting components down the hole.
My control box is very simple. It has a contactor and a capacitor in it. The contactor is controlled by a pressure switch at the pressure tank. Because the box has plenty of room I have an extra contactor and capacitor in it. In sealed packages. So when the pump controller fails on a snowy holiday when we have a house full of overnight guests because a cap or contactor or both fails I have the replacements right there and "Ready To Be Proudly Displayed". Or at least installed if nobody wants to tramp out into the snow to keep me company while I brag about my foresight.
The upshot is that I still fail to understand why someone would prefer a 2 wire pump over a 3 wire pump.
Eric
   / Submersible well pump recs please #18
For me it's because the controls on the 3 wire are susceptible to failure and lightning hits that the 2 wire are not. I've replaced multiple control boxes due to failure but never a 2 wire pump.
Wow, that really surprises me, that the 3 wire controls are that much more susceptible to failure. I just don't understand why, what would make them this way. I guess I can understand lightning strikes on a box just mounted out in the weather. But I don't understand what makes the 3 wire controls intrinsically that much more prone to failure. Can you explain?
Eric
   / Submersible well pump recs please #20
It's widely known among well contractors that the external electrical components don't last as long or are not as robust as the internal cvomponents. The reason I originally had a 3 wire pump is because it was a 2 HP. If your pump is going to be larger than 1.5 HP then a 3 wire is probably best and may be your only choice. Around here you don't even see anything 3 wire that is 1.5 HP and below. Most well heads are not the best environment to place such an enclosure. I never looked at the rating on mine but I doubt it was even a NEMA 4 enclosure.
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
DOUBLE WALLED FUEL TANK/TOOL ROOM SKID (A50854)
DOUBLE WALLED FUEL...
JOHN DEERE 450H CRAWLER DOZER (A51406)
JOHN DEERE 450H...
2013 Case 84in Hydraulic Hopper Sweeper/Broom Skid Steer Attachment (A49461)
2013 Case 84in...
2019 HONDA PIONEER 5 1000 UTV (A50459)
2019 HONDA PIONEER...
2019 TOYOTA 8FGCU25 PROPANE FORKLIFT (A51222)
2019 TOYOTA...
