Submerged tractor
/ Submerged tractor #21
Be very gentle turning it over by hand.
Don't hesitate to split the tractor and drop the oil pan at the first sign of binding. Sometimes it gets ugly. :(
/ Submerged tractor #22
I actually did this late last fall in Michigan so the water was cold but not freezing. I'd say probably around 45 degrees. Sounds like most of you guys are pretty mechanically savvy so when people say to crank the engine manually I'm not aware of what exactly to do. What's the procedure? At least the fan mystery is solved.
You can use the starter if you use a starter button and just bump it by hitting it with the palm of your hand quick or a socket on the front crank bolt is what these guys are talking about. :thumbsup:
/ Submerged tractor #23
You can also just jack up a rear wheel, make sure you don't have differential locked if it has that or not in 4wd and slowly spin a tire with it in gear. Be careful because you will have some gear mutiplication working against you if it is going to bind up. 1 wheel turn will be ? engine turns.
/ Submerged tractor #24
I'am not sure but your saying you did this late last fall and your now just getting to do this stuff????. I'am not sure if you drained any of the water when it happened if not??your due for a motor overhaul now!!! Any water that would have been on top of a piston would have drained into the oil pan by now.If there was lots of water in the oil pan plus in the hydralics man are you going to have to rebuild this tractor.Sorry for the bad news but thats what it sounds like to me.Then again it's going to depend on how deep it was in the water and how much made its way into the oils etc:.Larry
/ Submerged tractor #25
If any water got into the cylinders at all..........the cylinder walls will be rusted, as well as the rings..........we're talking 6 months or so of sitting after it was submerged.
Definitely needs a rebuild.
/ Submerged tractor #26
It does seem a long time to leave it before thinking about fixing the problem
But you may have been lucky
You may find it is just water in the electrics as it a gas engine it may have cut out before any damage occured
Then again it may be worse i had the job of repairing my brothers engine that he got on a little deeper than it could swim and had to cut the corner off the con rod to get it out
once that was done we removed the head and replaced the damage rod and it has been sweet since
the rod still hang on a nail in front the vice to remind him of his endevers
i would pull the plugs and turn it over have alook inside if all feels good then swing it over and see what happens
You didn't say if you tried to start it or not before you parked it up
/ Submerged tractor
It got pretty cold right after I sunk it and hasn't really warmed up here in SE Michigan yet so I haven't been too inclined to mess around with it yet. I did turn the ignition once after pulling all the plugs and just got clicking, no turnover.
/ Submerged tractor #28
OUCH! You will have most likely to pound the pistons out when you overhaul it and thats before boring or sleeving it and thats just the engine the rest will be....well I am sure glad its not me sorry to hear about it man but you have to get on it within hours if you hope to salvage it once they take on h2o most of us thought you had just sunk it when you posted sorry
/ Submerged tractor #29
ummm your situation just went from
bad, but salvageable to
good luck with that, start shopping for a new engine or tractor
If you are asking question about how to turn the motor over by hand, you lack the know-how to rebuild the engine. While there is nothing to loose in trying to get the current one running by doing basic stuff.
IMHO your looking at a full engine rebuild by a shop or a new engine or a new tractor as there is also questions about water sitting in all the other fluid areas, (Trans, hydrualics, axles etc)
/ Submerged tractor #30
i'd have at least filled the cyls with diesel .. heck.. entire engine with diesel.... drain the tranny and diffy and hyds and fill ALL with diesel vs letting it set up and rus tlike that.
bet every roller bearing and journal in there is rusted..
soundguy
/ Submerged tractor #31
soundguy
Oh absolutely that would have been a great idea bet he wishes that he did too that sure would have gone a long way keeping it viable until he could tear it down and fix it right.
/ Submerged tractor #32
Wow, been sitting, how long???? Might just have to really become a mechanic....or crack the checkbook for another one. Sounds like a real project coming up. Jy.
/ Submerged tractor #33
i've rejuvenated submerged machines... but somebody got then drained and filled with oil before letting them set. even though they set under water a couple weeks.. it is when they are out of the water that the rust gets them..
soundguy
/ Submerged tractor #34
soundguy
Okay, i bought a MB diesel engine that had only had "a little water down the injector"...I tryed to drive the piston out with a 4x4 block and sledge. Soaked it in diesel for a week and then kroil oil for a week. that piston is still in the block...
/ Submerged tractor #35
going in hot vs statonary with rising water makes a difference too.
IE.. driving into water is mre damaging that a tractor setting there and water rising and coveringit.
the one I saved was a flood victom from katrina from lousianna.
soundguy
/ Submerged tractor #36
I was a rebuilder and used/salvage car dealer for many years.
Once I bought and rebuilt a theft recovery Tacoma nice v6 4wd automatic ext cab loaded up 70k miles only had one fender bent and it came out out of a fresh water sand pit so I thought I was ok going to get it on and make some money on this one.
NOT even close it was a nightmare from hail lucky a good friend bought it and knew he may have electrical trouble because I told him he probably would I had fixed everything I was aware of he knew that.
Well he only had one issue and that was an SRS seat belt retractor went shorted and turned the airbag lite on long story short never again.
I did make him a good usable truck and he still has it but thats the last under water one for me I didn't make any money on it whatsoever.
/ Submerged tractor #37
well as some one has said bent con rods are more than litly if she was runing also water damage to the head if she has turned enough to damage it
then i would say its juast a case of drying her out puting new big end and small end shells in and assesing any other damage with out seeing her and hearing her run its very dificult to say
ask the older lads around wich most probs will not be on this but they have seen it time and time again do not worry lad your not the onaly 1
/ Submerged tractor #38
a wet tractor with 5 wires and very basic elecricals on it and a wet truck loaded with electricals IMHO.. are 2 totally different things..
soundguy
/ Submerged tractor #39
soundguy
Yup. A Massy 135 and a Toyota tocoma are 2 different things. No body computer on a Massy. I think the Tacoma got off easy.
/ Submerged tractor #40
yep.. the average old tractor from the 50's might have a starter, generator and voltage regulator as electricals.. plus a few switches and a relay or two..
chances are ALL but the switches could be salvaged with prompt cleaning...
not always so with things on printed circuit boards hidden all over the vehicle..
soundguy
2001 FREIGHTLINER FLD120 T/A 6X4 DAY CAB (A59911)
2001 FREIGHTLINER...
Altec Digger Derrick Hydraulic Boom (A61572)
Altec Digger...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
2021 CATERPILLAR 306 CR EXCAVATOR (A64279)
2021 CATERPILLAR...
2015 FREIGHTLINER CASCADIA 125 6X4 T/A GLIDER SLEEPER TRUCK TRACTOR (A59911)
2015 FREIGHTLINER...
H&H 500 GALLON T/A SPRAYER (A63291)
H&H 500 GALLON T/A...
