Backhoe Subframe on NH TC 40d
   / Subframe on NH TC 40d #1
hoot1293
Have a nh tc40d tractor with subframe on it for front in loader. Can this same sub frame be used to install a backhoe on this tractor.
I really could use a little help on this
   / Subframe on NH TC 40d #3
I have a TC40DA with a front end loader. I don't see how the loader frame could be used for a loader since it doesn't extend to the back. And a backhoe is quite heavy. I know there are 3 point mounted backhoes, but I woudl not want to put that much weight on my 3 point. Probably will have to bolt on a frame that you get from the backhoe manufacturer.
   / Subframe on NH TC 40d #4
Hoot I have the same tractor and I have an older Ford backhoe for it. My backhoe has a subframe with it that interconnects with the loader subframe. I agree that the 3 pt backhoe is not a good idea, they put too much stress on rear housing. My loader subframe comes to the rear of the tractor and attaches with the ROPS framework. You could conceivably fab up a backhoe frame to connect with it. Depends on the backhoe you have in mind though, does it have a subframe with it or can you order one specific to your tractor.
Thanks for the info.
2004 GMC Sierra 3500 (A55973)
2004 GMC Sierra...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A55315)
2021 Unverferth...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A55315)
2023 Unverferth...
John Deere 5055E (A53317)
John Deere 5055E...
PumpJack Brand Pump Jack (A55315)
PumpJack Brand...
