Backhoe Subframe on NH TC 40d
   / Subframe on NH TC 40d #1
hoot1293
Have a nh tc40d tractor with subframe on it for front in loader. Can this same sub frame be used to install a backhoe on this tractor.
I really could use a little help on this
   / Subframe on NH TC 40d #3
I have a TC40DA with a front end loader. I don't see how the loader frame could be used for a loader since it doesn't extend to the back. And a backhoe is quite heavy. I know there are 3 point mounted backhoes, but I woudl not want to put that much weight on my 3 point. Probably will have to bolt on a frame that you get from the backhoe manufacturer.
   / Subframe on NH TC 40d #4
Hoot I have the same tractor and I have an older Ford backhoe for it. My backhoe has a subframe with it that interconnects with the loader subframe. I agree that the 3 pt backhoe is not a good idea, they put too much stress on rear housing. My loader subframe comes to the rear of the tractor and attaches with the ROPS framework. You could conceivably fab up a backhoe frame to connect with it. Depends on the backhoe you have in mind though, does it have a subframe with it or can you order one specific to your tractor.
Thanks for the info.
2022 Polaris Ranger Utility Cart (A55787)
2022 Polaris...
2015 Ford F550 Bucket Truck - Altec AT40M Boom - Powerstroke Diesel - Automatic Transmission - 4X4 (A55302)
2015 Ford F550...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A56435)
2018 John Deere...
flooring (A55758)
flooring (A55758)
2005 Freightliner M2 106 Ambulance (A56858)
2005 Freightliner...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A56435)
2017 Yale GLC050VX...
