Backhoe Subframe for 3pt backhoe
/ Subframe for 3pt backhoe #1
vulcancowboy
Duncannon, Pennsylvania
Kubota L3400 HST
I have a Kubota L3400 and a BL4690 3pt. backhoe. I don't use the hoe very often, but would prefer to convert the hoe to subframe mount. I recently ran across a Kubota kit #L4691 that appears to do just that. Questions:
Does anyone have any experience with this kit? Does the installation of this kit effect use of other 3pt equipment, i.e. mower, blade, etc?
Thanks in advance!
/ Subframe for 3pt backhoe #2
Do not know on that model but, I have a BH77 on a sub frame and you have to remove the lift arms to install it. When the hoe is off the lift works like it is suppose to.
/ Subframe for 3pt backhoe #3
Mine too. To clarify, on mine, the subframe stays on all the time. When I take the hoe off, I put the lift arms back on. Takes maybe 10 minutes or so.
2019 INTERNATIONAL LT625 T/A 6X4 SLEEPER TRUCK TRACTOR (A59912)
2019 INTERNATIONAL...
2020 Cat 302.7D Mini Excavator (A64047)
2020 Cat 302.7D...
2022 CATERPILLAR 310 EXCAVATOR (A62129)
2022 CATERPILLAR...
H&H 100 GALLON ALLY WAY SPRAYER (A63291)
H&H 100 GALLON...
2007 Ford F-750 Water Truck w 2,000 Gallon Tank (A63689)
2007 Ford F-750...
1985 Ford Ltl9000 Tender Truck (A63688)
1985 Ford Ltl9000...
