Stuttering hydralics
/ Stuttering hydralics #1
Cutterhead
Washington
Kubota L3400
I have a Kubota L3400 and the last few times I've used it I've noticed that as I raise the FEL it will go up smoothly a bit, then stutter as it goes up, then smoothly. It also seems like the steering is doing the same thing when I turn the wheels. Fluid level is fine. Doesn't matter the engine RPM. Cold or hot. Any suggestions?
Thanks!
/ Stuttering hydralics #3
Check for air in the system.
Inspect the suction hose and re-tighten all clamps.
I couldn't see any specific holes, but there was clearly a leak; the hose was covered with gunk. Looks like a relatively easy fix - but a bit shocking that a part like that would fail on my tractor with less than 175 hours - and it seems I'm clearly not alone on this one.
Thanks for the help!
2020 HYDREMA 922GHM ARTICULATING DUMP TRUCK (A65053)
2020 HYDREMA...
3pt 2 Row Bedder (A64119)
3pt 2 Row Bedder...
Toro Z Master Professional 72in Zero Turn Mower (A61572)
Toro Z Master...
UNUSED ATSPOWER PLASMA CUTTER (A64281)
UNUSED ATSPOWER...
1993 WhiteGMC WG Tri-Axle Dump Truck (A61573)
1993 WhiteGMC WG...
2005 Butler pole trailer (A62679)
2005 Butler pole...
