Stupid Questions: 1 to ....
   / Stupid Questions: 1 to .... #11
I use a 9" auger to put in 6" posts. Many a time when I hit rocks I wish I had a 12" auger. So, I think your choice of 9" & 12" is right on.
Remember to go slow (idle speed) clear often and have a big pipe wrench (36") to back out the drill when (not if) it gets stuck. Don't let anyone stand near it either. Happy boring!
   / Stupid Questions: 1 to .... #12
Congrats! You'll be satisfied with that setup. As recommended, get a bigger rotary cutter. The frame mount backhoes are surprisingly easy to remove and mount.
With rock removal, the box blade may work depending on what type of soils you have. For sand and loam, you could tilt it forward and use the ripper teeth to loosen/dislodge them and then collect them in the box with another pass. Iffen it's clay, you may want to try a different approach. I use the backhoe!
The loader will lift about any rock you can get into it. I suggest a rock tooth bar to strenthen the bucket edge, as I have already bent my naked bucket edge by jockeying rocks over one ton. Be sure the rear tires are loaded, and that you have plenty of counterweight on the rear (such as the backhoe).
With the augers, I use a 6" for 4x4s, which offers a more snug fit. Then I give it a nice press with the loader. No backfilling with gravel. In heavy clay soils, one backfills all holes with clay or you wind up with a swimming holes. With permeable soils, it's a different story, of course.
   / Stupid Questions: 1 to .... #13
You did not mention which type of tires you want to go with. I have Industrials and highly recommend them, they have great grip like AG's and are easy on your lawn like turfs. If ground engaging work is your main task, you may also want to look into having the tires "filled".
Another great addition I am glad users here mentioned when I bought my tractor was hooks welded to the bucket. Just a few hooks welded to the top lip of the bucket, they are so useful and great to have.
46493d1130559663-finally-placed-my-order-today-762404-img_5330-cropped-bucket-100k.jpg
I have a 60" rear mount snowblower and it is just as easy to put on/take off as any three point attachment with the addition of a slide-on driveshaft. You will love the cab in the winter, don't forget the heater.:D
With the rake, box blade and blade you may want to look into a hydraulic top link. For a couple hundred bucks more you will have infinite control of the vertical angle of the attachment from inside your cab. It even helps with the adjustments of the snowblower. Good luck and Happy shopping!
   / Stupid Questions: 1 to .... #14
Not sure if they come standard with the DK45 but the two rear hydraulic remotes are not standard on my CK30 and I wish that I had paid the extra price for them. Also, a grille guard was not standard and I ended up buying one from Kioti after a few front end mishaps.
   / Stupid Questions: 1 to .... #15
I believe the DK series come with one set of rear remotes. Adding a second is trivial during set up and cost only about $300-350 at last years prices. I agree that it is well worth getting them installed but I also think it is not that difficult to do it outside the dealership so long as you can take a rear wheel off safely.
IT, HB, Dmace,
I am going with ag tires for a couple of reasons: limited supply options up here, will not be on lawn, mostly working in woods, pasture and moving manure around as well as snowblowing on gravel lane.
It comes with one set of rear remotes. Will look at second set, but my budget is getting tight.
We live in a beautiful part of the world - unfortunately at times, it seems we are in the middle of no-where and at the end of the supply routes....
I can weld the hooks on - please not another set of how-to photos!!!! :)
It comes with a brush guard but no grill guard - that I can fab myself.
For weight on the back I built a concrete block with 2" receiver hitch in place as well as receiver tubes for tool carriage - I will post this item - neat design.
Thanks...
to quote my 3 year old son - "4 more sleeps" before I meet with the dealer.
   / Stupid Questions: 1 to .... #17
Make sure you reinforce the bucket if your welding hooks on!
Will reinforce loader...
Ordered today. Will arrive in two weeks.
DK45 shuttle with cab and attachments.
Loader kl 451
kb 2485 BH
Post hole & Auger 9" and 14"
7' landscape Rake
7' blade
6' rotary cutter
7' box blade with rippers
6' snow blower
4" chipper
4'x8' harrow
sand spreader
She has the list started - not in the yard yet.
Other than tooth bar & thumb, this should get me through the next 15 years hopefully. Tractor and implements will be housed - that's on the list too.
Lots happening in the next little while.
Pics to follow...stay tuned.
Lloyd
   / Stupid Questions: 1 to .... #19
congrats and welcome to the pack.
I just put hook on my loader and posted pics, used c-channel to reinforce top of bucket. Super strong and will last indefinately.
Good luck with you new machine and attachments. Lots of nice stuff their and welcome to the pack!!
And to quote my little one "wear your seatbelt for safety".
Sincerely,
Joel
2016 Toro Workman HDX-D Diesel Utility Cart (A59228)
2016 Toro Workman...
PALLET OF 12IRON GATES (A58214)
PALLET OF 12IRON...
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
2008 New Holland T2420 (A60462)
2008 New Holland...
Massey Ferguson 9250 (A56438)
Massey Ferguson...
