Stumps
/ Stumps #1
sonofczechgun
Old Dominion
B1750HST 4WD
Good Evening
I have an oak (about foot in diameter) knocked down on my land - from Isabela I believe.. Yesterday I decided it is time to do something about it and I hooked it to my B1750 and tried to move it around to get the stump out. What I tried was to use the log as a leverage and break the rest of roots from the ground.
Well, it didnt work. The only thing I got out of it was checking the functionality of 4x4 and dif lock - I was able to spin all 4 wheels in the same tiime:)
Anybody has a trick or sugestion what to do about fallen down trees or stumps left from fallen down trees? I rip the logs with a chainsaw into boards, but the stumps I dont really want around.
/ Stumps #2
If you don't have a backhoe to dig it out, a stump grinder is probably your best bet. Even full size TLBs have trouble pulling out stumps.
/ Stumps #3
Speedy has it right. Pulling/pushing a stump out of the ground is something you do with a dozer. You can dig them out with an excavator - the quick approach or take a little longer using a backhoe or mini-excavator. If you have a loader, a lot of space to work in and plenty of time, you can even dig a crater around the stump big enough to knock it loose.
Your trick of using the trunk of a fallen tree for leverage might work, but you probably need a bit more tractor to take on a 10" oak that way.
If your ground is as dry as ours around here right now, the roots are pretty solidly in the ground at the moment. You might try adding water to soften things up, but don't get carried away!
/ Stumps #4
I have a similar problem with some trees in an old logging camp road I am clearing to make a drive to my house. After the trees are cut down. A buddy of mine suggested making burn barrels and putting them on the stumps full of dry firewood. And burning them out. He said that he has seen them burn even the roots as far as 15 ft. away from stump. Sounds a like good idea to me if you are in an area that burning is allowed.
/ Stumps #5
If you are set on pulling it out, Backhoe, breaking one root at a time. You may even have to keep digging out from trunk to expose more root so it will break. If you do not have backhoe and want to pull stump out only other thing I've done is expose each root branch by digging it out and carfully cut each root with chain saw. you need to get as much dirt away from where you are going to cut root. It will not do the chain much good, but should get it loose enough where you're tractor will pull the stump out.
/ Stumps
Looks like I got the answer I expected:)
Two more tricks I heard of:
- cover the stump with manur, thats what amish do and it accelerates the rottening.
- use sawzall to cut the roots - the blade is much cheaper than the chain on a chainsaw.
If I feel playful, I will give it another shot with my CJ7 - I6/4.2 could do better than 20HP tractor.
Thank you, everybody
/ Stumps #7
I've heard of people digging a small trench around the stump, putting a metal ring (or barrell) around the stump, filling the trench and the base of the stump with charcoal brickettes, and lighting it off.
Some have taken a wood spade bit and drilled one inch holes down the stump to open it up some.
No personal experience, sorry.
ron
/ Stumps #8
I've got a 45 hp L4400 w/FEL and for most larger stumps it is useless. (Soil is hard clay and rock) What has worked for me is using a 1" augur bit and drilling multiple holes in the stump, straight down and from the sides. Fill the holes with diesel or kerosene and let them burn.
As mentioned, it is dangerously dry in this part of the world and it is very easy for a fire to get out of hand quick, so waiting for wetter weather would be advised around here.
/ Stumps #9
I've tried the dig it out by hand route, and the burn it out, and pull it out, and wait to let it rot out method. Nothing beats a big old back hoe. It might be overkill for just one stump, but if you can line up a few other jobs for the hoe while you have it, rent or borrow one. I borrowed one last weekend and got as many as nine stumps out in one hour, without breaking a sweat. Left me wondering what a shovel and an axe are for. Another buddy loaned me his track hoe this past weekend. It was a compact Caterpillar with a 24" bucket. It worked fine, but the JD Back hoe from last weekend was hard to beat. I'm up to about fifty stumps out of the ground in the last two weeks and just about done for a while with the stumps. Time to start digging the footers for the new house, but when I get that done I'll still have plenty of stumps to deal with in the other two acres yet to be cleared. I'll resort to the backhoe again when that time comes.
On another note; I went to an equipment rental place to talk to them about stump removal. When I mentioned stumps they didn't want to rent me a backhoe. They said a backhoe was strickly for digging dirt and could be torn up with stumps. They would only rent me a dozer for stumps. He then proceeded to show me a fairly small dozer he assured me would do the job of pushing them over. I wonder. I have numerous stumps that were cut very close to the ground. It seems that a dozer would need some leverage and what happens when the stump breaks off without getting the root ball out of the ground? I didn't want to leave clumps under ground to rot and leave soft spots and sink holes.
/ Stumps #10
You have nice friends--letting you use their nice toys!
ron
/ Stumps #11
You are correct, a dozer needs a bit of leverage unless you want to cut on either side then push it out of the hole.
</font><font color="blue" class="small">( I've tried the dig it out by hand route, and the burn it out, and pull it out, and wait to let it rot out method. Nothing beats a big old back hoe. It might be overkill for just one stump, but if you can line up a few other jobs for the hoe while you have it, rent or borrow one. I borrowed one last weekend and got as many as nine stumps out in one hour, without breaking a sweat. Left me wondering what a shovel and an axe are for. Another buddy loaned me his track hoe this past weekend. It was a compact Caterpillar with a 24" bucket. It worked fine, but the JD Back hoe from last weekend was hard to beat. I'm up to about fifty stumps out of the ground in the last two weeks and just about done for a while with the stumps. Time to start digging the footers for the new house, but when I get that done I'll still have plenty of stumps to deal with in the other two acres yet to be cleared. I'll resort to the backhoe again when that time comes.
On another note; I went to an equipment rental place to talk to them about stump removal. When I mentioned stumps they didn't want to rent me a backhoe. They said a backhoe was strickly for digging dirt and could be torn up with stumps. They would only rent me a dozer for stumps. He then proceeded to show me a fairly small dozer he assured me would do the job of pushing them over. I wonder. I have numerous stumps that were cut very close to the ground. It seems that a dozer would need some leverage and what happens when the stump breaks off without getting the root ball out of the ground? I didn't want to leave clumps under ground to rot and leave soft spots and sink holes. )</font>
/ Stumps #12
I've removed about 100 stumps ranging from one foot up to six feet in diameter with our backhoe and never had any problems.
A BH will out stump a dozer any day of the week.
/ Stumps #13
I agree with SkyPup, I also have many stumps removed by BH. A dozer is like a bull in a china closet, if your being selective on your tree/stump removal a BH or excavator is the only way to go.
/ Stumps #14
</font><font color="blueclass=small">( I agree with SkyPup, I also have many stumps removed by BH. <font color="red">A dozer is like a bull in a china closet,</font> if your being selective on your tree/stump removal a BH or excavator is the only way to go. [/color:"blue"]
Perfect analogy IMHO. Want to rip everything up?..Use the dozer...want to be selective...use the BH.
/ Stumps #15
</font><font color="blue" class="small">( If I feel playful, I will give it another shot with my CJ7 - I6/4.2 could do better than 20HP tractor.)</font>
Bad news, I have used my Rubicon with an 8K winch on it to pull trees I was cutting and for "trying" to pull stumps. The first thing you will need to do is use a tow strap to hook the back end of the Jeep to a LARGE tree. Without that all I did was drag the Jeep around in the dirt.
When you get through trying that you will discover that even an 8K winch will only pull about a 4" stump at best. Oh, BTW, watch it if you pull small stumps, they can become missiles when they finally break loose.
At least I got to play with my winch.
If you can put up a "For Rent" sign and get a family of fireants to move into the stump they will eat all the cellulose out of it in about a year and then you can push it over with the FEL.
So far, that is the only known thing fireants are good for. I have several families of them on long term leases right now with some pine stumps. I will evict them and the stumps about this time next year! If you need fireants I have plenty I will be willing to give you.
Bill Tolle
/ Stumps #16
I did use my 9,000 pound Warn winch to finally remove this massive six foot diameter live oak stump, but only after I had worked on it for days with the FEL... /forums/images/graemlins/blush.gif
/ Stumps
Hello Jeeper:)
I had a good luck with a tree down and my Jeep. But it was an old and dry maple - not an oak knocked down green and still pretty much fresh. But i had to pull it one way and than the other way using the leverage of the trunk to brake the roots.
Fire ants sound good - but not sure how to get them to Virginia:)
/ Stumps #18
Now ya know where to dispose of the used oil you drain out of that Jeep or your tractor. TREE STUMPS!
Ive been working on a 40 inch ash here for more than a year.....soaking it with old oil and diesel fuel...and next week I'll be "laid up" because of an eye operation...so I figure I might as well break out the highway flares and light that booger off...while sitting in my easy chair watching it... /forums/images/graemlins/grin.gif
/ Stumps #19
Speaking of stumps becoming missiles:
A good buddy of mine, many years ago was helping another friend pull stumps from a pasture they were prepping for a horse arena. The stumps were mostly in the eight inch range with the normal ups and downs. The soil was sandy and easy to work with, so they would dig a bit, and pull a bit using a pickup truck for the muscle. All went well through many stumps, until this one pesky bugger.
When I saw the pickup the next day I noticed the rear window missing and asked the buddy what happened to his truck. He told me I hadn't seen anything yet, so we went over to have a closer look. The windshield was also missing. Then he showed me the dashboard. Broken pieces and parts everywhere from the flying glass caused by the rear window breaking. "What the heck happened," I asked.
That pesky little stump proved to be a stubborn little devil and they were tiring from all the digging. In fatigue inhanced desperation the pickup truck was backed up a bit farther, and gunned a bit harder, and the stump came loose. The tail gate was down so the stump sailed undisturbed through the rear window of the truck, smashing the interior from the force of flying glass, then flew through the windshield. But, it was not done. The rope, yes, the rope got tight again when the stump reached the end of the line, and back snapped the stump knocking out the front grill and bending the hood, before finally falling to the ground. Flight time total; about a half second. Fright time, they're still talking about that one, and lucky to be talking.
When the stump flew through the truck it hit pretty much dead center of the cab, barely missing the head of my buddy driving the truck. It would have took his head off. The truck was nearly totalled.
Moral of the story. Don't you use no stretchy rope on stumps.
Have fun.
Tom
/ Stumps #20
I'm from the school that teaches not to create stumps in the first place. Most 1 foot trees can be uprooted with a small tractor if the soil conditions are right. Too late for that, and it's not your fault. Blame it on the hurricane. /forums/images/graemlins/smile.gif
If you can't mooch a back hoe, try this:
Buy a bottle of Green Light stump remover. It's 99% pure saltpeter (postassium nitrate). Follow the directions.
In addition to the directions, dig around the stump before treating it, and make sure it's good and dry before attempting to burn it. The season almost rules that out.
Do not use diesel, gas, or oil. The flames are impressive, but they only act as coolant as they evaporate. If you can get a big fan or leaf blower to blow on the stump while burning it, that helps a lot. Heavy firewood helps a lot too. I once melted a 2 footer with firewood and a leaf blower. It left a 2 foot deep ash pit that just begged for a 60 pound pig. /forums/images/graemlins/wink.gif
2015 CHEVROLET 2500 HD CREW CAB FLATBED TRUCK (A62130)
2015 CHEVROLET...
2012 Ford Expedition SUV (A61574)
2012 Ford...
2016 Ford F-150 Crew Cab Pickup Truck (A59228)
2016 Ford F-150...
2017 Case CX145D (A60462)
2017 Case CX145D...
CATERPILLAR 299D2 SKID STEER (A60429)
CATERPILLAR 299D2...
2017 GMC 3500 Enclosed Service Body Truck (A62613)
2017 GMC 3500...
