Stump plane
/ Stump plane #1
marhar
Denton NC
Farm Trac 60
Does anyone have experience with a stump plane like the one in the attachment? The seem costly and I will probably never buy one.
/ Stump plane #2
That is the first 3 point mount that I have seen.
I have watched a few YouTube videos of the skid steer versions:
/ Stump plane #3
They do the job. I had someone do two for me and worked great. Wouldnt buy one just for personal use unless you have many to do.
If so you could buy it....use it.... and sell it when done.
/ Stump plane #4
Danuser makes a smaller one to fit their hydraulic post hole diggers. Down pressure, forward reverse, gpm and pressure requirements.
/ Stump plane #5
See thread at Forums>Related Equipment>Skid Steer Loaders>ETERRA AUGER STUMP PLANER? started by MNBobcat on June 15, 2020.
Watch a PTO driven one in action at this link: Rotor S 15 – 25 Hp with drill.
/ Stump plane #7
I wouldn’t want to be near it when operating
Unlike the American buzz-saw stump grinders that turn at several hundred RPM, the vertical-axis European stump grinders turn at much lower RPMs and are unlikely to throw projectiles. Some of the videos show the augers used to grind stumps on the verge between curb and sidewalk; pedestrians walk by, and the windows of storefronts are unprotected. Any American contractor would have the sidewalk cordoned off and screens in front of any windows.
/ Stump plane #8
Interesting
/ Stump plane #9
A coupe of the videos I had referenced in #7 with by-standers or nearby windows. First uses an open "drill"; second uses a core-type "cylinder" (Stump ejected near end.)
/ Stump plane #11
Almost all of the videos I have seen were made by the company that is marketing the machine. As one might expect, rocks are never identified as a problem. I would speculate that the bits are robust enough that a slip clutch or shear pin in the pto shaft or by-pass in an hydraulically driven grinder would trip before the bit were damaged. One of the US manufacturers, I think it is Fecon, states that the bits are easily repaired or replaced in the field, Take that for what it is worth.
/ Stump plane #12
I wondered about rocks too. We have lots of them. I have a water line that goes under a rock I couldn't get out with a trencher. But then I wonder how those stump grinders with high-speed wheels do in rocks.
/ Stump plane #13
Short answer: About as well as rotary lawnmowers.
Longer story: My fascination with vertical axis stump grinders is a pipe dream. Prices start around $18K and require a high flow skid steer, 100+ HP tractor, or a several ton excavator, none of which I have. I purchased a 24" horizontal axis "buzz-saw" stump grinder for around $5K.
I live on a hill of glacial till, everything from clay to boulders the size of small cars that was bulldozed by the glaciers. Before I grind a stump, I excavate a bit around it to remove easily handled rocks and identify the location of boulders not easily moved. I will still encounter rocks and, while I have not (yet) broken a carbide tooth, I have sent a golf-ball-sized "pebble" flying 20' despite the mud-flap-like deflector..
2022 EZ-GO ELITE...
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
2019 Deere 35G (A64126)
2019 Deere 35G...
John Deere S350 (A60462)
John Deere S350...
2017 International Prostar 122 Day Cab (A62613)
2017 International...
