Stump jumper??
/ Stump jumper?? #1
BlueToy1
Central Missouri
Kubota MX6000
Several threads discussing rotary cutters have referred to a stump jumper. Being from the county I've heard of stump broke(not from experience), but I'm not familiar with a stump jumper. The name implies it assists the cutter over a stump. Could somebody tell me what it is and how do tell if a cutter is so equipped, please?
/ Stump jumper?? #2
The blades on the cutter attach to a round or oblong 'pan' under the shredder. When it encounters a stump the blades swing out of the way and the 'pan' rides over the stump. Without a stump jumper the blades just attach to the shaft coming out of the bottom of the gearbox and the risk of a bent shaft is more likely.
/ Stump jumper?? #3
It's just a round disc of sort that the slapper blades are attached to that is rounded up on the outer edges. That way, if it hits a stump, it makes the cutter jump up and bounce over it rather than stick into it. It's a very simple idea and most all should have them.
/ Stump jumper??
Ahhh thanks guys, now that you explain it, I recall seeing it under there.
/ Stump jumper?? #5
Like the others have said, the pan rides over stumps... It also is where the cutter gets it's momentum from. The bigger/heavier stump jumper, the heavier stuff the cutter will go through without slowing. Some of the heavier cutters have 200lb.+ jumpers...
2007 FREIGHTLINER M2 106 4X2 26FT BOX TRUCK (A59912)
2007 FREIGHTLINER...
2004 Gradall XL3100 Highway Speed Wheeled Excavator (A64194)
2004 Gradall...
1996 FRUEHAUF 45' SLIDING AXLE FLATBED TRAILER (A59911)
1996 FRUEHAUF 45'...
SDLD25 Crawler Dumper (A64047)
SDLD25 Crawler...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
UNVERFERTH PERFECTA II 18' FIELD CULTIVATOR (A63291)
UNVERFERTH...
