Stump Grinder
   / Stump Grinder #1
JohninCT
Platinum Member
Central CT
Struck Magnatrac 6000, Kioti DK40SE
Here's some pix of a stump grinder that I put together for my Magnatrac. I bought the hydraulic motor and cutter wheel from Power Trac (one sized for the PT 425). I made up the bracket to fit on my backhoe in place of the bucket (used 5 inch channel, 3x3 and 2x2 angle). Its gonna take some time to master the technique of effectively (and safely) grinding with it, but maneuvering it with the backhoe controls seems to work good. /forums/images/graemlins/smile.gif
Its fair to say that this is one "implement o' destruction" /forums/images/graemlins/cool.gif
John in CT
   / Stump Grinder
Another view
   / Stump Grinder
Closeup of cutter head
   / Stump Grinder
Here are some action shots of the first victim (a 24 inch apple tree stump).
   / Stump Grinder
A check after a few minutes to see the progress and to see if everything holding together /forums/images/graemlins/wink.gif So far so good /forums/images/graemlins/smile.gif
   / Stump Grinder
This shows the cutter way down below ground level (about 8 or 9 inches - wheel diameter is 18 inch)
   / Stump Grinder
Watch that flying debris /forums/images/graemlins/shocked.gif
   / Stump Grinder
Here's the final pic showing the completed job. Filled the hole back up with all the chips.
   / Stump Grinder #9
John,
If you don't mind me asking, how much does Power Trac charge for a cutter and motor like you have?
1982 GOOSENECK 24FT TRAILER (A52472)
1982 GOOSENECK...
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
2023 JOHN DEERE 8R370 LOT NUMBER 200 (A53084)
2023 JOHN DEERE...
378810 (A51572)
378810 (A51572)
2012 CATERPILLAR 279C2 SKID STEER (A51246)
2012 CATERPILLAR...
