Stump Grinder
   / Stump Grinder #1
JohninCT
Platinum Member
Central CT
Struck Magnatrac 6000, Kioti DK40SE
Here's some pix of a stump grinder that I put together for my Magnatrac. I bought the hydraulic motor and cutter wheel from Power Trac (one sized for the PT 425). I made up the bracket to fit on my backhoe in place of the bucket (used 5 inch channel, 3x3 and 2x2 angle). Its gonna take some time to master the technique of effectively (and safely) grinding with it, but maneuvering it with the backhoe controls seems to work good. /forums/images/graemlins/smile.gif
Its fair to say that this is one "implement o' destruction" /forums/images/graemlins/cool.gif
John in CT
   / Stump Grinder
Another view
   / Stump Grinder
Closeup of cutter head
   / Stump Grinder
Here are some action shots of the first victim (a 24 inch apple tree stump).
   / Stump Grinder
A check after a few minutes to see the progress and to see if everything holding together /forums/images/graemlins/wink.gif So far so good /forums/images/graemlins/smile.gif
   / Stump Grinder
This shows the cutter way down below ground level (about 8 or 9 inches - wheel diameter is 18 inch)
   / Stump Grinder
Watch that flying debris /forums/images/graemlins/shocked.gif
   / Stump Grinder
Here's the final pic showing the completed job. Filled the hole back up with all the chips.
   / Stump Grinder #9
John,
If you don't mind me asking, how much does Power Trac charge for a cutter and motor like you have?
1261 (A50490)
1261 (A50490)
2012 Kenworth W900 (HEAVY DUTY) (A52748)
2012 Kenworth W900...
2018 Kinze 3500 Planter (A52349)
2018 Kinze 3500...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A52748)
2024 BCL...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
1995 BEALL TRAILER FUEL TRANSPORT PUP TRAILER (A52472)
1995 BEALL TRAILER...
