Chipper Stump Chippers
/ Stump Chippers #1
adampahl
Does anyone here have any experience with stump chippers? I am thinking about purchasing one mostly for home/farm use but will probably end up doing some custom work once people hear I have one. My question is which kind is best. PTO powered, trailer style, self propelled??? I am leaning towards a 3pt pto model. They are the cheapest and seem like they would work the fastest. I have a JD 3010 to run it. The only down side to these I can see is that it won't be very portable. (only be able to take it as far as I want to drive the tractor) Any comments would be appreciated!
/ Stump Chippers #2
Depending on how big and how many stumps you think that you will be doing. I do tree work as a side job. I don't do grinding though. The guys that are doing stump work all tend to have grinders that are tire driven and portable enough to move easily in tight spots such as through a fence gate into a yard. That might not be an issue for you. What you might do if it is easy enough is go rent one for a day and see what you think. Tractor powered would be nice but I think you might have issues with portability.. Just my 2 cents worth.
Jim
/ Stump Chippers
Thanks for the replies so far. I am going in on it with my father and brother who live near by. We Maintain a total of 6 building sites so If my math is right from last time I hired a stump grinder it won't take long to pay it of at $4,500 for the 3pt version new. I've got about 25 stumps right now!
/ Stump Chippers #5
I have rented a stump grinder before. cost around $250 for 8 hours. Was Vermeer that pulled behind my truck. I was able to grind about 50 stumps in 10 hours. Most were pine (easy) some were oak(slow). When you consider the cost I would consider renting. No maintenance between uses.
/ Stump Chippers #6
I think there is a Woods stump grinder for... about $2800 IIRC, about a year ago.
EZ Trail 3400 Seed Tender Wagon (A64047)
EZ Trail 3400 Seed...
SHOP BUILT 3PT SPRAYER (A63745)
SHOP BUILT 3PT...
2020 Peterbilt PB337 S/A Dump Truck (A61573)
2020 Peterbilt...
Friesen 240 Seed Tender (A63116)
Friesen 240 Seed...
2020 John Deere HPX615E Gator 4x4 Diesel Utility Cart (A61572)
2020 John Deere...
2012 John Deere 6430 102HP Agricultural 4WD Tractor (A61572)
2012 John Deere...
