Stump Chipper
/ Stump Chipper #81
Mr. JCoastie, based on your initial use, what are you finding your average time for grinding - let's say an 18 to 20 inch diameter stump?
Mostly Southern pine here ... if it's a fresh stump of that size, it can take upwards of 15 minutes. If it it's old and dry, it could be under 5 minutes.
Oak and some other varieties here can be a real bear and take upwards of 20 minutes. Almost all of mine are on a hillside so I have some extra grinding to do to get the change in elevation right so that my bushhog will not dig in and get a stump strike later at some point.
/ Stump Chipper #82
damn zerk broke clean off when I removed the grease gun on the bearing closest to the PTO. That was a 4 hour delay to get the old one out, and a trip to town to get a replacement from TSC. Be careful with that one. It's an M6x1.0 zerk.
Harbor Freight sells boxes of zerk fittings for about $6. I replaced several 45 degree fittings on my older attachments. The 45s are two-piece in most cases so I didn't have to use up the few 45s in the HF package... I could just replace the tip which screwed onto the the 45 degree base. The base is screwed into the attachment.
let's see if the HF cheapies last very well.
2011 Armstong Marine Pilot House Boat w/ T/A Boat Trailer (A59231)
2011 Armstong...
2017 Ford Taurus Sedan (A59231)
2017 Ford Taurus...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
(INOP) 2015 POLARIS SPORTSMAN ACE 570 (A59823)
(INOP) 2015...
Deere 335P (A53317)
Deere 335P (A53317)
2016 Textron T/A 15 Ton Flatbed Equipment Trailer (A59230)
2016 Textron T/A...
