Stuff happens
/ Stuff happens #11
I've sometimes wondered why people don't run something like 1/8" aircraft cable through the 3/8" chain links. If the chain breaks the cable will contain it most likely, and anything with enough force to break 3/8" chain will shrug off 1/8" (the 1/8" in turn will be contained by the now sagging weight of the 3/8" chain links once the 1/8" cable slack is taken up).
This is the same sort of idea as running 1/8" through the linear springs of garage doors to stop the broken spring pieces from flying around when the springs inevitably break under tension.
Cable through a chain would make it rather unruly to store
Tom in Vermont
/ Stuff happens #12
Why? Very simple; they didn't expect the chain to break.:D
/ Stuff happens #13
for heavy pulling, put a break-away (weaker link) near the hitch, so that if the chain breaks it will snap away from the tractor. I simply make a shallow hacksaw cut 2 or 3 links away from the hitch. That way I know that I'm not going to get whacked.
Bill:D
/ Stuff happens #14
could the driver have made a sudden jerk instead of a steady pull?
I would place my bet with that...
Using Cat track tractors I have pulled a lot of chain in two. Always destroys the complete chain by collapsing most of the links. I have never seen a chain flip unless it was yanked and failed due to a sudden shock load. A steady pull can eventually exceed the load rating but the chain will not fly wildly... cable will. KennyV
/ Stuff happens #15
You could also run the chain through a metal pipe to help contain it should it snap. Wonder how high up the chain was connected or how near to the gentleman's head. But when it is your time...
/ Stuff happens #16
A trick I have always used (learned it while working in an underground mine where hiding places are hard to find) is to keep something heavy and droopy (short piece of heavier chain, half full sand bag, roped together wheel chocks, etc.) on the pulling unit. When you are planning on stretching some cable, hang the weight near (about 1/3 of the total length) the tractor, if something breaks the weight will pull the cable towards the ground and away from the operator.
/ Stuff happens #17
There is no easy answer here, other than stay out of the way. When we were into 4-wheeling we carried an old blanket to hang on straps, chains, cables, to weight them down and slow them down. Bottom line was stay clear. Starps are no safer, we broke a 4" strap, it's force great enough to gice a guy a black eye that covered most of one side of his face AFTER partially removing his tailgate. The stored energy in these things is amazing.
The Flood Farm up here in Maine had a close call last fall during the harvest. While pulling out one large piece of equipment with a larger piece of equipment, the CHAIN they were using broke. It removed the rear window of the pulling tractor and still have force enough to leave some nasty marks around the head of the operator. Thing I don't understand is they swapped to a cable for prevention of reoccurrence.
ANY material will stretch and store energy. Bottom line if you're worried about it is not to exceed the break strength of whatever you're using and inspect it before use. Chains wear and fatigue, cables fray, and straps chafe and fray.
E
/ Stuff happens #18
So will straps.
2025 JMR Single Cylinder Grapple Bucket Mini Skid Steer Attachment (A59228)
2025 JMR Single...
Crown SP3550H-30 Stand-On Electric Forklift (A59228)
Crown SP3550H-30...
1985 CADILLAC SEVILLE (A60736)
1985 CADILLAC...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
2019 Ford F-550 4x4 ETC37IH 37ft Insulated Bucket Truck (A59230)
2019 Ford F-550...
2016 FORD TRANSIT T250 CARGO VAN (A59575)
2016 FORD TRANSIT...
