Stuff happens
/ Stuff happens #2
Chain, cable, strap.. if any of them breaks under stress they can become lethal. I do more than my share of pulling/towing, at home and at work. I'm extra careful, but if something fails at the wrong time.....:(
My condolences to his family..
/ Stuff happens #3
You gotta be careful when you do stuff like that.
/ Stuff happens #4
Darn shame. :(
/ Stuff happens #5
Slowly replacing all my chains (for towing, pulling) with 2-4" nyloy crain straps.
Nick
/ Stuff happens #6
This puzzles me because I have always heard that it was much safer to tow with chains than straps or ropes because they don't stretch and store up kinetic energy. I heard if a chain breaks it should more or less just drop to the ground instead of whipping back like a stretched rope does.
Could it be that the chain was attached to something else that streched and whipped it back? Or could the driver have made a sudden jerk instead of a steady pull? I go very slow and easy when pulling with chains and I sure hope I am not exposing myself to more danger than expected.
/ Stuff happens #7
Op1 to op2 "just give it a good yank"
Tom in Vermont
/ Stuff happens #8
With chains, you don't really see the visible stretching but there is some. And of course what ever is pulling on it, will also move forward a tiny bit when the chain breaks. As a volunteer firefighter, one of the grass fires we fought was the result of a loaded dump truck trying to pull a stuck mobile home mover truck with a chain. When the chain broke, it knocked sparks off some rocks and started the fire. Or at least that's what the truck drivers told us, and I think they were telling the truth.
/ Stuff happens #9
I've sometimes wondered why people don't run something like 1/8" aircraft cable through the 3/8" chain links. If the chain breaks the cable will contain it most likely, and anything with enough force to break 3/8" chain will shrug off 1/8" (the 1/8" in turn will be contained by the now sagging weight of the 3/8" chain links once the 1/8" cable slack is taken up).
This is the same sort of idea as running 1/8" through the linear springs of garage doors to stop the broken spring pieces from flying around when the springs inevitably break under tension.
/ Stuff happens #10
Reminds me of that gag pic of the "OSHA" approved horse.
John
/ Stuff happens #11
Cable through a chain would make it rather unruly to store
Tom in Vermont
/ Stuff happens #12
Why? Very simple; they didn't expect the chain to break.:D
/ Stuff happens #13
for heavy pulling, put a break-away (weaker link) near the hitch, so that if the chain breaks it will snap away from the tractor. I simply make a shallow hacksaw cut 2 or 3 links away from the hitch. That way I know that I'm not going to get whacked.
Bill:D
/ Stuff happens #14
I would place my bet with that...
Using Cat track tractors I have pulled a lot of chain in two. Always destroys the complete chain by collapsing most of the links. I have never seen a chain flip unless it was yanked and failed due to a sudden shock load. A steady pull can eventually exceed the load rating but the chain will not fly wildly... cable will. KennyV
/ Stuff happens #15
You could also run the chain through a metal pipe to help contain it should it snap. Wonder how high up the chain was connected or how near to the gentleman's head. But when it is your time...
/ Stuff happens #16
A trick I have always used (learned it while working in an underground mine where hiding places are hard to find) is to keep something heavy and droopy (short piece of heavier chain, half full sand bag, roped together wheel chocks, etc.) on the pulling unit. When you are planning on stretching some cable, hang the weight near (about 1/3 of the total length) the tractor, if something breaks the weight will pull the cable towards the ground and away from the operator.
/ Stuff happens #18
So will straps.
2017 Ford F-450 XL (A64911)
2017 Ford F-450 XL...
Accu-line TCX Tire Changer (A64912)
Accu-line TCX Tire...
John Deere 9320 (A64911)
John Deere 9320...
2012 18ft Gastron Boat with 18ft Magic S/A Boat Trailer. (A64557)
2012 18ft Gastron...
2018 CATERPILLAR 259D SKID STEER (A65056)
2018 CATERPILLAR...
1996 DODGE RAM 1500 LARAMIE SLT EXTENDED CAB TRUCK (A65057)
1996 DODGE RAM...
