Stuck shift forks Mf 265
   / Stuck shift forks Mf 265 #1
Dill
NH
1962 IH 606, JD 2440, JD 5410, MF 265, MF 271XE, 58 Case 420 Shovel dozer
My 265MF has now jammed the trans on me twice this season. I've been able to pull the cover off and get the forks aligned without much effort, but I was just wondering what I could to eliminate the need to carry a long screwdriver with me. Is this a problem with the shifter or the forks? We used to a have an old farmall that would do this and it turned out to be a worn shifter.
   / Stuck shift forks Mf 265 #2
Its the same problem with lots the shifter does wear out.What I've done is to pull the shifter and build the end up a bit by welding it.I build it up with weld ever so little maybe 1/8 " all around and it gets rid of the problem.If you do build it up too much you'll know because you won't beable to shift,if thats the caase just grind a bit off.Larry
2021 Chevrolet Silverado 1500 Custom Crew Cab Pickup Truck (A48081)
2021 Chevrolet...
2023 Komatsu WA320-8 Articulated Wheel Loader (A49461)
2023 Komatsu...
2023 Chevrolet Tahoe SUV (A48082)
2023 Chevrolet...
2019 Komatsu PC490 Hydraulic Excavator (A49461)
2019 Komatsu PC490...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2000 Toro Groundmaster 223-D Commercial Mower (A49346)
2000 Toro...
