Stuck shift forks Mf 265
   / Stuck shift forks Mf 265 #1
Dill
NH
1962 IH 606, JD 2440, JD 5410, MF 265, MF 271XE, 58 Case 420 Shovel dozer
My 265MF has now jammed the trans on me twice this season. I've been able to pull the cover off and get the forks aligned without much effort, but I was just wondering what I could to eliminate the need to carry a long screwdriver with me. Is this a problem with the shifter or the forks? We used to a have an old farmall that would do this and it turned out to be a worn shifter.
   / Stuck shift forks Mf 265 #2
Its the same problem with lots the shifter does wear out.What I've done is to pull the shifter and build the end up a bit by welding it.I build it up with weld ever so little maybe 1/8 " all around and it gets rid of the problem.If you do build it up too much you'll know because you won't beable to shift,if thats the caase just grind a bit off.Larry
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A51039)
2021 John Deere...
1999 Ford F-800 Vacuum Truck (A50860)
1999 Ford F-800...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A51039)
Kubota 24in Quick...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
2009 Ford Ranger Pickup Truck (A48081)
2009 Ford Ranger...
2022 Ford F-150 4x4 Crew Cab Pickup Truck (A48081)
2022 Ford F-150...
