Stuck PTO shaft
/ Stuck PTO shaft #21
MJPetersen said:
No I would loctite the nut and never seize the shaft!! But I still hope for your sake that you do not have to dismantle it again. ;) :D Put the nut and the loctite on first--otherwise you will get the never "sneeze" on the nut and the loctite will not avail.
Mike
Exactly. Just don't get it on the threads. If your like me, you will have it all over you when your done. I do every time.
Don't forget to put it on the blade pins either. I had to have one pin cut out and have one now that needs it. You have to have a very big torch to cut through that length of metal. It is a wonderful design but they need to put the never seize part in bold print in the manual.
/ Stuck PTO shaft #22
Put a full coat of loctite on the threads it will work as a type of never sieze while keeping everything tight.
/ Stuck PTO shaft
I ended up using my Dremmel tool with a grinding stone to clean up the rust. Wire brushing just bernished it. Put the new seal in and put plenty of "never seize" on the PTO coupling and few drops of "ever seize":rolleyes: (AKA. Loctite on the threads). Hopefully it'll stop leaking when I put it all back. I hate to revisit it again anytime soooon:D :D
JC
/ Stuck PTO shaft #24
Looks good!! 3 and a half days and your 30 minute project is done!!:D
Mike
/ Stuck PTO shaft #25
so does that big nut set the preload on the bearing that holds the gear/shaft?
/ Stuck PTO shaft
I don't think so. The big nut turns with the rotation of gear and provides backing for the shaft seal. At first I thought the nut may hold the gear in place but on further inspection It became apparent that the gear/shaft and the two cups (6) and two sleeves (3) are pressed in place. There were no adjustment I could make. Over tightening the nut (2) would squiz the seal against the sleeve causing damage to the seal. I hope I answered your question.
JC
/ Stuck PTO shaft #27
Oring 'picks' are good for that sort of thing!
soundguy
JC-jetro said:
Jerry, It is exactly how is shown in your pic. The problem I had was the type of spring loaded concentric snap ring they used. I could not use any snap ring compression hand tool, had to bend the tip on a small screwdriver to kind of gouge it out of there. Not very convinient at all but quite stout. it appears all the early pulling and pushing and beating did not phase it at all and the ring looks in good shape. Thanks for your inpuut.
JC:)
/ Stuck PTO shaft #28
I can't help but wonder this, if the nut is hitting the seal before is it tight on the collar that the seal rides on then is it possible that the seal needs to be seated deeper in the housing? It would seem a nut that big and heavy is designed to hold some serious pressure on something versus being a seal protector. In looking at the top pic in your photo set I see a lip down in the housing along the outside edge, I believe that is where the seal should be seated to.
/ Stuck PTO shaft
Bucmeister,
You're perfectly correct in your statement. Perhabs I should've used more appropriate terminology when I said nut is the seal protector. On my previous post on pic #1 , you see the sleeve right next to the pto shaft thread. when I removed the old oil seal it was pretty flush or "deeply seated" with the top of the sleeve. The bottom of the big nut is perfectly flat and once you tighten it it keeps the sleeve in place. Sleeve seems to be press fitted in the cone bearing with the rollers. When the front seal started leaking my first reaction was to tighten the nut which stopped the leaking but it started back again after few weeks. Over tightening that nut pushes the sleeve against the bearing causing the shaft not rotate freely. Probably you would not want too much play there but it should be snug fit. The inner lip of the seal with the spring coil seals the oil passed the sleeve (#3 part on parts breakdown) and not actual PTO shaft. Obviously seal is not rotating but the combination pto shaft with the sleeve is. I wanted to post another more clear pic but I have technical issue with the posting site I use right now. I hope I made myself clear.:)
Sound guy,
O ring Picks ?? did you mean to take the seal out with that? Normally that is the preferred method. I have a set of those picks that I use for self adminstered dental work:D :D or picking rings as you mentioned. The shaft seal was pretty stout and flush with the sleeve. That left me nothing to grab to. I ended up ramming a screw driver in to it and mutilated it before I was able to retrieve it. New seal installation is a one shot deal ... you do it right or you destroy the seal. I don't reckon you can remove the seal without damaging it. It was still though when I put the new one in. It was pretty tight.. once I got it partially in, I used the main nut with the flat bottom to seat it in fully.
JC
Ps. My hosting site is back up. here is a better pic. I'll post the parts breakdown again also...
/ Stuck PTO shaft #30
Bucmeister is right in that the nut is the method by which the preload is set on the bearings. Looks just like a front wheel spindle setup (except the spindle rotates and the wheel flang stays still :rolleyes: ).
You need to make sure that the nut does NOT rub against the seal, close but not touching. And the nut should be torqued to some setting probably given in the service manual, maybe owners manual.
The bearings and the sleeve may be pretty tight on the shaft, but there has to be a way to set preload on them and without that nut there is NO way. One thing possible.
Good call Bucmeister
Mike
/ Stuck PTO shaft
soundguy
My bad Soundguy:( , I should learn to read first.Your reference was to my attempt of pulling the concentric snap ring or whatever it is called. I shoud have use that instead of bending the tip of small screw driver. I know could not pull our the seal with the pick. Picks that I have not stout enough and would bend.
JC
/ Stuck PTO shaft
Your right bucmeister. as you said the seal should not hit the rotating nut. I took the nut and pushed the seal a bit recessed using a flat pencil as wooden punch. It moved a Little less than 1/8''.. may be 3/32". Packed the bearing with some grease, put some loctite and put it all together. The manual says that the bearing is pressed in and no further adjustment is necessary.I had the nut tight and turned back just a hair to allow rotation of gear without a lot of flop.
/ Stuck PTO shaft #33
By the way.. Nice pics JC!!
Soundguy
/ Stuck PTO shaft #34
shure give him all the credit for the "big nut sets the prealod on the bearing" ;)
its like putting a pinion together on a third member.... on a thirdmember they take like 8billion lbs of torque to set. (well ok ONLY 180-200 but its as good as 8 billion when your hanging off the end of a 3' cheeter bar)
/ Stuck PTO shaft #35
Soundguy
someone knows how to use the "flower mode" (cough macro cough) of his camera ;)
/ Stuck PTO shaft
Schmism,
I cain't (with a twang) help it. Just the way I am I reckon ;) :D
JC
Hays LT-1 Tender (A61307)
Hays LT-1 Tender...
Arrow Quip RLDR Alleway Roll Door (A64047)
Arrow Quip RLDR...
2008 UTILITY VS2DX 53X102 DRY VAN TRAILER (A59910)
2008 UTILITY VS2DX...
2021 Ford Explorer AWD SUV (A61574)
2021 Ford Explorer...
2018 HYUNDAI VC2530152-JS DRY VAN TRAILER (A59575)
2018 HYUNDAI...
2016 JCB 510-56 10000 LB Telehandler (A64047)
2016 JCB 510-56...
