Winches Stuck in the mud, help me pick a winch?
   / Stuck in the mud, help me pick a winch? #21
   / Stuck in the mud, help me pick a winch? #22
I put a 8000 pound US made winch on my Jeep bumper. The first thing I found out was I needed a second battery which led to an isolator protecting the starting battery. I installed a deep cycle winch battery which takes discharges better than a starting battery. I also figured out I needed a high amperage alternator, so I added one of those. It takes a while to charge the battery back once you run it down.
Don't forget if you double the winch cable you double the pulling power. I can pull 16000 pounds by looping back my cable. The problem I ran into was I ripped the front bumper out of the Jeep frame and I had to weld up my Jeep frame. I added more steel to make it stronger.
A winch takes some planning. And make sure you are safe by putting a blanket over the wire incase it breaks. I have burned out my winch motor once. The local alternator shop was able to rewind the motor.
   / Stuck in the mud, help me pick a winch? #23
If you can, chain a log that is 2' longer than the diameter of your back to the outside of one or both rear tires. The logs sticking out a foot on each side will give you tremendous traction although it will rock you a bit.
Tom
2015 Vermeer SC362 Stump Grinder with 2018 S/A Flatbed Trailer (A53421)
2015 Vermeer SC362...
1999 Southwind Fleetwood 34N 34ft Class A Motorhome (A55853)
1999 Southwind...
Scotsman Ice Maker (A56469)
Scotsman Ice Maker...
2012 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A57880)
2012 FREIGHTLINER...
2020 Bobcat LT313 (A53317)
2020 Bobcat LT313...
WHIRLPOOL WASHER & KENMORE ELITE DRYER (A54757)
WHIRLPOOL WASHER &...
