aczlan
Good Morning
- Joined
- Mar 7, 2008
- Messages
- 17,540
- Tractor
- Kubota L3830GST, B7500HST, BX2660. Formerly: Case 480F LL, David Brown 880UE
If the ground is too soft to support the backhoe bucket, cut some 4 inch or so chunks of tree that are 4 ft long and use those as a mat underneath the backhoe bucket to give you something to spread the weight of the tractor on. Then you can lift up the rear tires and put more chunks of tree underneath the rear tires and the front tires.I've used the backhoe curl to pull, simultaneous with uncurling the front loader to push, to inch back out of an almost-stuck. Literally an inch at a time. Would that work?
Also if the backhoe can lift the tractor off the ground, do that and put planks under the tires.
Finally, for backing out, I've found if the front tires are badly embedded then lifting the front with the loader and tobogganing back with the weight on the flat bottom of the bucket instead of on the tires, worked better than trying to drive backward.
Do you really have a tree nearby that will anchor a 12k pull? I'm certain I would rip my apple orchard trees out of the ground before a really stuck tractor would start to move.
Summary - try to get something under those tires.
If you are stuck deep enough that you can't get out with the backhoe bucket, a winch is going to have a very hard time getting you out.
Aaron Z
