stuck hydraulic drain plug
/ stuck hydraulic drain plug #1
Greg_Thomas
Charlottesville, VA
Mahindra 4110
I attemped to replace the 4110 hydraulic fluid and filters and couldn't get the square drain plug out. It has 1300 hours and probably has never been opened. I put vice grips on it and banged on it but I decided heat from a torch wasn't a good idea. Anyone know where I can get a square drive wrench for the drain plug?
Once I get it off, is there a generic size replacement for it?
Also, the fuel filter is hard to get to with a FEL. Any suggestions for getting that off with minimal swearing?
/ stuck hydraulic drain plug #3
Greg,
I'm not sure about the size of the square head but you might be able to find an 8 point socket at a auto parts store. Or a few tricks I've used on other square head plugs is using the female end of a socket extention over the plug and a large wrench(15" cresent was my choice /forums/images/graemlins/shocked.gif) on the male end or possibly a stud extractor would work and the last ditch, backs against the wall solution would be drill(have a drain pan ready!) and EZ-out. Well thats my 2 cents, give your post a few days, there's a lot of sharp people on this website I'm sure someone's had this problem and has a better idea. Best of luck
Spike42
/ stuck hydraulic drain plug #4
Greg,
Spike42
/ stuck hydraulic drain plug #5
just get a high quality tight fitting open end wrench, you may have to beat it on the plug since you already used vice grips, then beat on the wrench with a small slege hammer. it should come right out.
/ stuck hydraulic drain plug #6
/ stuck hydraulic drain plug #7
There are sockets made specially for removal of this type of plug. You can get them from Snap On, Mac, etc. , you might be able to get craftsman as well. Good luck!
/ stuck hydraulic drain plug #8
/ stuck hydraulic drain plug #9
Levrage is what you'll need not banging. If you can get a pipe wrench on it I have had luck with pipe wrenches and the like with a pipe on the end for leverage.
/ stuck hydraulic drain plug #10
/ stuck hydraulic drain plug #11
leverage is good but pipe wrenches and vice grips teas stuff up too much for me, of course im kinda pickie.
/ stuck hydraulic drain plug #12
/ stuck hydraulic drain plug #13
I know this sounds elementary, but have you tried tightening the plug first? Often times that will cause a stubborn nut, plug, screw, etc. to break loose. Watch those knuckles.
/ stuck hydraulic drain plug #14
Cattle Feeder (A65640)
Hydraulic rail grinder (A61307)
Hydraulic rail...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
4021 (A59228)
4021 (A59228)
New Idea 201 Manure Spreader (A66408)
New Idea 201...
2022 YANMAR VIO55-6A EXCAVATOR (A63276)
2022 YANMAR...
