stuck height adj. on bx2200
/ stuck height adj. on bx2200 #1
Anonymous Poster
Epic Contributor
Has anyone experienced the height adjustment knob for the MMM to get stuck or frozen and not turn. Something seems to be in a bind.
/ stuck height adj. on bx2200 #2
I find if I lift the deck all the way to the top and then turn the knob, it does not bind, if I do not , then I can not turn it. Try raising the deck via the 3 pt control and see if that helps.
Tom
/ stuck height adj. on bx2200 #3
I've had the same problem - do as GoYankees said - that's what I do with mine.
/ stuck height adj. on bx2200 #4
Lift the 3 point hitch (and mower) to the top, then adjust the height adjustment knob. I believe that’s the way it should work. If not you have a problem.
I had the same problem. My was caused by the shaft binding on the sheetmental where it passes through. The hole was not centered, so I filed the hole a little oblong. Works fine now.
/ stuck height adj. on bx2200 #6
Check your rotary mower manual, pg 12 & 13 both say to raise the mower to the highest position & then to adjust your cutting height control dial.
HD Bale Ring w/ Hay Saver (A66408)
HD Bale Ring w/...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
2017 Case CX145D (A62177)
2017 Case CX145D...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2012 MACK GU713 DUMP TRUCK (A63276)
2012 MACK GU713...
Bulk Lot - Used Steel Transfer Pipe & Fittings (Chuck Pipe) (A63689)
Bulk Lot - Used...
