Stuck gear
/ Stuck gear #1
Keith 321
Ford 1900 1983
How to fix my Ford 1900. It’s stuck in 2nd gear
/ Stuck gear #2
I don't know your tractor but when my Mitsubishi would stick in second I could remove the plate holding the gearshift to expose the gears inside. I could then use a pry bar or screwdriver to pop it out of gear. I could then put it all together again and it would work fine until the next time.
/ Stuck gear #3
When you remove the top plate, check to see if the shifter will move. Sometimes there is a spring detent ball that is stuck. Or check your gears to see if they are stuck, and why.
/ Stuck gear #4
This happened to my Ford 1720 a couple of times. Was able to rock the tractor with the front end loader enough to take the pressure off the transmission and pop it into gear. I'm careful now when shifting gears and it hasn't happened since. 1450hrs are on the hour meter.
/ Stuck gear #5
Yep. That's usually where that problem is. Often an easy fix and sometimes due to rainwater running down the shifter. Take the cover off and have a look.
Freighliner Tender Truck (A61307)
Freighliner Tender...
2016 Troy-Bilt 18in. Push Mower (A60352)
2016 Troy-Bilt...
2025 GPS Trailers (A56857)
2025 GPS Trailers...
2020 DRAGON ESP...
HUSQVARNA RIDING...
iDrive TDS-2010H...
