stuck front wheel
   / stuck front wheel #1
fishman002
I have a B20 that has set out during a recent ice storm and now the front right wheel is stuck and it will not rotate. I tried to rock the tractor back and fourth to free it but no luck. Is it frozen or broken? It might add that it worked perfectly two weeks ago.
   / stuck front wheel #3
IT will take awhile for it to thaw if frozen!
   / stuck front wheel #4
I have seen the front end of cars and trucks freeze up after being driven on a slushy road and then have a hard freeze over night. You will pretty much have to let it warm up or add heat to break it lose.
   / stuck front wheel #5
When the wheel of a car or truck freeze it is because you got water into the brakes and when they freeze it is just like the brakes are on and nothing moves. I find it very difficult to think that an ice storm could do anything to the wheel of a tractor that would cause the wheel not to move. I am afraid that you have a bigger problem than just waiting for warmer temperatures.
   / stuck front wheel #6
He's right. It sounds like you have water in the gears that froze and is locking them up. Whatever you do, don't force it, or it will definitely be broke. Get it good and warm, and it should rotate, then drain the oil on this side to get rid of the water. This is assuming you have a 4x4 tractor.
   / stuck front wheel #7
If the tire itself is just frozen hard to the ground, try pouring a 5 gal bucket of HOT water around the bottom of tire where it meets the ground.
   / stuck front wheel #8
If you have a garage you could put the tractor in 2wheel drive and put the bucket down to lift the tire off and slowly move the tractor in side to warm it up. I would let it set overnight before I would try moving. I would also would leave the drain plug out while letting the warm up to let as much water out as possible. I would refill it and drive it around for a little bit and change the oil again.
   / stuck front wheel
Thanks for everyones input. Well I got it unstuck. I lifted all four wheels off the ground using the outriggers and the FEL, applied heat to the hub, and rocked the pedal from forward to reverse and slowly the wheel began to rotate. I like the oil draining idea. There is most likely water in it.
   / stuck front wheel #10
If you have a garage you could put the tractor in 2wheel drive and put the bucket down to lift the tire up and slowly move the tractor in side to warm it up.
I think I would try to spin the wheel before dragging it in on the bucket.
No use dragging it if the wheel will turn.
RYOBI 2900 PSI GAS PRESSURE WASHER (A51248)
RYOBI 2900 PSI GAS...
2019 Caterpillar 299D2 High Flow Compact Track Loader Skid Steer (A51691)
2019 Caterpillar...
19200 (A50324)
19200 (A50324)
21010 (A51694)
21010 (A51694)
JOHN DEERE LOT NUMBER 110 (A53084)
JOHN DEERE LOT...
