Stuck clutch
/ Stuck clutch
I've tried starting it in all 4 gears in low range with the clutch held down and then hitting the brakes hard, which worked fine in the past when it did it, but hasn't helped at all this time
/ Stuck clutch #13
1. Chain the tractor to a stout tree, put in in reverse in a low gear and back up
2. Use a stout tree and drive the tractor forward
Unless the clutch is behind the transmission, which I doubt, your clutch and clutch force are always in the same direction with the engine, irregardless of whether you are going forward or backwards
/ Stuck clutch #14
Not sure how that is relevant but if you say it is, it must be.
2014 BMW X1 S Drive 28I SUV (A59231)
2014 BMW X1 S...
2016 Ram 4500 Wrecker/Snatch Truck, VIN # 3C7WRKAL4GG243467 (A61165)
2016 Ram 4500...
2016 Dodge Grand Caravan Van (A59231)
2016 Dodge Grand...
Kubota L4701 (A53317)
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
Zero Turn Mower (A59231)
Zero Turn Mower...
