stuck clutch
/ stuck clutch #1
warburtonplayer
I have a shibaura S700 4WD and one part of the clutch is stuck. When I got the tractor the guy told me he used it and then left it for a while then came back a few months later and could not get it started and then it sat for about a year. I have been spraying PB blaster on it and one side came loose and the other is still stuck. It will not pull start because the clutch is stuck. I sent the starter off to get a rebuild so hoping the new starter will have enough power to start it up. When I tried pull starting it really wanted to start but would choke out because of the clutch. Does anyone have any ideas or tricks besides breaking it apart?
/ stuck clutch #2
Is this a gear transmission tractor? Why can't you put it in Neutral and start it that way? Can you pull to start AND hit the starter at the same time? You are pulling it in top gear, right?
Most of the remedies need the tractor running. You then block the peddle down and turn sharp circles and hit alternate brakes. My favorite is to get a good bottom plow and just start plowing. While plowing, occasionally jump on both brakes. And I do mean a good jump and stomp! Don't hold it down, you just want to put a big shock into the system that will cause the clutch to slip free.
With the PB ->> turn the engine over 1/2 turn by hand and spray.
After you have it free, you will need to block the clutch down, remove the starter and spray about a case of brake cleaner on the clutch. Turn the engine by hand 1/4 turn at a time and get it all. Use up a can making 1 turn. Wait about 1/2 to 1 hour, then repeat for a total of 3 cans. Then do some (10-12) top gear starts at high throttle to both burn off the rust and the residual oil. You will probably have to use 6 to 12 cans to get a double clutch oil free. It just depends on how saturated it got and how easy it is it actually get the cleaner onto it.
Since it is 1/2 free now, you should be able to get it free with out a split.
good luck!
jb
/ stuck clutch #3
That often happens to an old Jeep I have. I find that it is more effective and much easier to put a load on the clutch by pulling the machine so the rear wheels turn the clutch rather than having the engine do it. I put it in second gear, leave the ignition off, press in the clutch pedal, and then pull it fast enough to spin the engine at 1500-2000 rpm. Every time, after a minute or two of that it breaks free.
If you have something to pull with, put the tractor in the top or next to top gear, push in the clutch, and pull it a while. You should not shut off the fuel because it is needed to lubricate the injection pump. The best, but messiest way, is to loosen the fuel lines at the injectors so the fuel does not make it to the cylinders. But if you don't want to do that, keep the "throttle" at idle speed, and even if the engine starts it should still be getting turned by the rear wheels if you pull at a pretty good speed.
/ stuck clutch #4
Although I can not say that I have previous experience with the pickle you're in but willing to take a stab at it if your PTO is transmission driven....
As you said, you have the starter out, so I can see you can stick a pry bar, good size screwdriver or whatever that you can to temporarily jam the flywheel causing it not to rotate. I would then put the PTO lever in engaged position to couple the PTO shaft with the transmission. I then, will get a beefy pipe wrench and for good measure a respectable pipe cheater bar. I grab the PTO and try gently but with authority to turn the PTO shaft while blocking the clutch pedal to simulate (clutching action). This effort should cause the whole shaft to turn which at the end is splined to clutch plate. That may coerce the clutch plate to let go off of the pressure plate, flywheel or both. I'll give it a try , can't see how you can harm anything if you don't go over board. good luck:)
JC
/ stuck clutch #5
JC
JC,
I've heard this is a way that works - never used it. Do you hook up an implement and then put the pipe wrench on the pto shaft? I can't see getting enough room to grab and spin it anyother way.
jb
/ stuck clutch #6
Make sure there is no pto brake involved..
Soundguy
/ stuck clutch #7
john_bud said:
JC,
jb
John,
That makes two of us (never done it myself either). One probably can use half of the PTO shaft from an implement, mount it on tractor PTO shaft, jam a slender pipe in the yoke and turn. When I attempt to tighten the front seal on my brush hog I always jam a pry bar in the yoke to keep the shaft from rotating so I can tighten the big seal nut.
JC
/ stuck clutch #8
We have put our tractor in gear and two people rock it back and forth the slack in the transmision will shock the clutch loose sometimes. Give it all you got and sometimes it will work. The other way is hitting the bake hard while moving as JB said.
/ stuck clutch
Yes I sprayed the clutch with a few cans but still cannot get the one side unstuck. I am hoping when i get my starter back I can start it up and then the vibrations will jar it loose. I only paid a couple hundred dollars for it!!! It is actually in good condition only 879 hours on it. All mecahnics work pto, hyd, all the valves are free imjector system works, If I could only get it started.
/ stuck clutch
Also I think it might but froze in 4WD? When i tried pull starting it, it just felt like it was pulling the 4WD also. What are the chances of it breaking free after I get the darn thing started? Like I said before I only paid a few hundred bucks for the tractor and I f I can get a low budget fix I think I might make out with a great little tractor for well under $1000.
/ stuck clutch #11
Can you jack up tractor on 4 jack stands. By disengaging the 4 wheel drive and turning the rear wheel manually you should be able to prove or disprove your "4 WD" stuck theory. Ford 1700 is not a big tractor, and I know, I can raise 4 wheels and support the whole tractor on 4 jack stands with the help of few 2x6's if needed in nothing flat, it's worth a try.
JC
/ stuck clutch #12
QUite the deal!
I was thinking. You may have air in the fuel system. You may want to crack the injector lines and bleed the them while pulling, then see if it will start. That could be why it "wanted to" but didn't start. Could also be gunked up. Have you put on a new fuel filter? Then add a qt or more of diesel fuel conditioner like PowerService, Howes or similar. (Hint, they all use 50% to 97% mineral spirits as it cleans the gunk but doesn't dissolve seals).
Good luck with it!
jb
/ stuck clutch
I have not changed I did check the fuel filter yet. I did check the injector sytem and ecrything was working well. I should have a anwser soon on where there or not it will start also I will send a few pictures.
/ stuck clutch #14
I'd suggest that once you get the starter back to try and fire it up and drive it around the field a few times and the clutch will probably free up. I did this with a car a few years ago the had a stuck clutch. I got it out in the street and started it in gear then drove it a few miles shifting without using the clutch. By varying the speed up and down while driving the resistance against the clutch plate broke it loose.
/ stuck clutch #15
I think the best way is to start the tractor in nuetral. The clutch switch is on the linkage so down is ok even if the clutch isn't letting loose. Concentrate on getting the engine running, where it will start and then go to the clutch.
Once you have it where it will start easily, I would try pull starting it in a high gear with the ignition off and the clutch in. If that doesn't work, load the tractor while running and increase the load with the clutch pedal down till it breaks the disc loose.
Make sure the clutch linkage is actually engaging and disengaging the clutch and all is free in that area before trying to break the disc loose.
MAKE SURE YOU ARE NOT IN A CONFINED SPACE AND HAVE A WAY OUT AT ALL TIMES, EVEN TO A POINT OF BEING ABLE TO DRIVE THE TRACTOR TILL IT RUNS OUT OF FUEL IF NEED BE. A TRACTOR THAT WON'T STOP IS NOT A SAFE THING SO BE EXTREMELY CAREFUL. CONSIDER ALL OPTIONS AND CONSEQUENCES BEFORE STARTING ANY METHOD OF BREAKING THE DISC LOOSE.
We don't need your widow posting that you ran over yourself trying to get on or off the tractor while running.
If this were mine, I would hook a truck to the front with a chain and another one to the rear of it from the drawbar. Pullstart it with the one in front and then load it with the pedal depressed by slowing down the vehicle in back till the clutch broke free.
I don't think I would try spinning the pto, as there is too much chance of breaking something back there. Parts are hard to find and not cheap when you find them should you break something.
David from jax
/ stuck clutch #16
Does your tractor have a large oval rubber plug on the left side of the bell housing? If it does, remove the plug, block the pedal down and drive a sharpened putty knife between the disc and flywheel or pressure plate face, which ever it is stuck to.
/ stuck clutch #17
Excellent if there. My JD stuck bad once and I didnt think of that. It has a very rigid strong front bumper weight setup, so I just put it in the lowest gear that would stall it at power and drove it dead on into a good heathy 14" tree at about 2MPH with hand on the kill switch. FIXED.
larry
/ stuck clutch #18
Spiderlk,
What ever works, I suppose .... but that wouldn't be my first choice of actions! I suppose it did the job and as they say, no harm no foul.
jb
/ stuck clutch #19
Actually that would have been my first reply if it weren't for not knowing what size bumper and tree he had available. I figured if he had a truck on either end of him pulling and pushing it would do the same thing and the one in front would keep him from going over should it not break traction.
David from jax
/ stuck clutch
ok so I got the new starter on, it fired up!!!!!! But,,,, the PTO seams to be stuck on? Not really sure what is going on. Also the Flywheel makes some strange noised while the engine is runing. I think it is all the old rust that broke off from being stuck for so long. any ideas about the PTO being stuck remedies?
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A67714)
2020 TROXELL...
ALLMAND ECOLED-RIG SPEC LIGHT PLANT (A67714)
ALLMAND ECOLED-RIG...
Unused 2023 Kubota AP-SSG2024 24in. Hydraulic Stump Grinder Skid Steer Attachment (A66734)
Unused 2023 Kubota...
Gravely Pro-Turn 148 50in Zero Turn Commercial Mower (A66734)
Gravely Pro-Turn...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
CHECO GREASE UNIT (A67714)
CHECO GREASE UNIT...
