stubby auger
   / stubby auger #1
IanM
Kenwood California
Kubota L2550GST
I need a pto driven auger that can access a 36" space. This would save me tons of labor costs. I'm planting 1,000+ grapes in-between vines of an established vineyard. The trellis system, which I can't remove, is a quadrilateral arrangement 36 inches off the ground and 18" wide. I only need a hole 12-16 inches deep and 12 inches in diameter. My Howse post hole digger run by a Kubota L2550 would do the job if the auger was shorter. I've done a quick search but haven't found anything commercially available. I'm looking at fabricating something and hoping for some suggestions.
Thanks for the help.
   / stubby auger #2
Have you looked at the augers from the smaller manual post hole augers and making an adapter to fit? The old 2 man style catch and break your arm! Kind
   / stubby auger #4
I just measured a bit for a Groundhog auger, it's 36". It might be worthwhile to buy one and cut it down and put the correct collar on for the pto drive. A specialty 14-16" bit can save a lot of time in positioning on 1000+ holes, and can be part of the bid.
   / stubby auger #5
mini skid steer unit, try your local rental yard and see if they can let you rent just the bit.
Augers
   / stubby auger #6
Cut your 12" auger down. I just cut one up to make a 12" auger reach a true 48" in depth. Fairly easy to do. Cut the spiral off and then shorten the drive shaft and reweld.
   / stubby auger
I think that makes the most sense. It will be a nice rainy day project.
2018 JLG 3246ES 32ft Electric Scissor Lift (A51691)
2018 JLG 3246ES...
2025 New/Unused LandHero 40 Gallon 2-Stage Air Compressor (A51573)
2025 New/Unused...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
Plasmarc PM150 Plasma Cutter (A51691)
Plasmarc PM150...
2004 Kenworth T800 Day Cab T/A Truck Tractor (A52377)
2004 Kenworth T800...
UNUSED FUTURE J5T TON 36" HYD THUMB CLAMP (A51248)
UNUSED FUTURE J5T...
